i need a new job..
get yaself a cheap pc such as the asus eeepc and start learning with that.
google linux tutorials too
its actually quite easy if you have a methodical approach to things and can easily break down what a command means, then its just practice makes perfect!
i have red hat 4???
linux / unix is paid well
its not somthing your going to learn over night, if ur literate with pcs already then this will help.
linux wise try something like ubuntu to get you started. this has both command line and graphical side (gui)
its free to download and is well supported! once your at a good level e.g being able to rebuild kernals and the like then go for somthing like slackware
if you want any help just give me a shout via pm
issues with installing or anything like that
both ubuntu, slackware and a few other distro's
dont work with linux as my main job.
we do run solaris 10 here at work
i just learnt linux for pentesting purposes
- im going to download ubuntu tonight again and then burn it to dvd and then get my pc built up and try and install it
