mk6 Fiesta brake light bulb change - help!
Old Oct 20, 2008 | 08:00 PM
RichieST's Avatar
RichieST
Default mk6 Fiesta brake light bulb change - help!
Hi all
Manual says undo the 2 screws and the light unit will come away from the car. I've done this, but it won't come away! It seems stuck in solid and won't shift! Can anyone help at all? Spent the last 10 minutes and have nearmy snapped my frigging fingers off Fooking stupid car gets on my tits
Cheers all
Rich
Old Oct 20, 2008 | 08:02 PM
focusbird's Avatar
focusbird
Open the boot, put your hand in the hole behind the light and you should be able to feel a wing nut, you need to un do that as well, then the whole light unit should come away from the car.
Old Oct 20, 2008 | 08:03 PM
djcossie's Avatar
djcossie
Default lol
Originally Posted by Rich170
Hi all
Cheers all
Rich
theys a wing nut on the inside mate
alan12112's Avatar
alan12112
Focus St mk2 310 bhp :D
beat me 2 it you 2
Old Oct 20, 2008 | 08:04 PM
gus's Avatar
gus
just need to give a little tug (ooooeeeerrr)
there is a couple of litle clips that hold it in
focusbird's Avatar
focusbird
Forgot to mention, it's easier if you have small hands
Old Oct 20, 2008 | 08:05 PM
RichieST's Avatar
RichieST
Oh right, just like my focus then!!
The bloody manual had no mention of a wing nut!!!
Will let you know in a couple of mins how i get on
Cheers!!!
Old Oct 20, 2008 | 08:06 PM
gus's Avatar
gus
no wing nut on mine
mine is the facelift version thou
wouldnt of thought they would of changed it, o well ignore my advice then
Old Oct 20, 2008 | 08:09 PM
focusbird's Avatar
focusbird
Yes, although on the Fiesta it gets worse. On the Focus the bulbs used to stay on the car and the casing came away, on the Fiesta the whole things comes off, THEN you have to un do about 7 little plastic clips around the light casing to get to the bulbs, its a bit tricky getting it back on straight. It's a right pain in the arse!
Old Oct 20, 2008 | 08:20 PM
RichieST's Avatar
RichieST
Just got it done! Found the little wingnut behind some wiring loom behind the carpet i had to pull away
Your right about the plastic clips that hold the bulb plate to the light unit, i undid 6 clips then the first 4 clipped back in. Stupid, stupid design!!!
Cheers all
Old Oct 20, 2008 | 09:12 PM
James's Avatar
James
then theres the 3rd brake light, they're ace fun !!!!!!!!!!!!!!!!!!!!!!!!!
JoeyBoyden
Jan 4, 2024 02:36 PM
Bosch
Aug 4, 2015 05:14 PM
adriansaleem
Aug 1, 2015 09:28 PM
