Whats the difference between a high pressure oil pump and not
looked on fleabay and there all high pressure 2wd oil pumps so whats the differnce in a std one and high pressure?
any type to look out for?
open it up, pressure relief valve needs making stronger by a tiny bit
apparently you can put a slim washer underneath to give you lots more pressure, it's as simple as that
but i only know one person who's done this with no bad tales to tell other than 70 psi cold and 45 psi hot at idle
All spring by thier nature are progressive, this used to be an old trick on mini's packing the relief valve in the block, or fitting in a steel ball, on the mini, old style proper mini not the modern rubbish.
big_Rad
Sep 15, 2017 09:36 AM
