headgasket?
Old Oct 20, 2008 | 04:26 PM
smerth54's Avatar
smerth54
Default headgasket?
right cars smoking alot i take it this means head gasket, cos the turbo still boosting fine or is there another reason 4 smoke? starting to wish i had kept me old frst
Old Oct 20, 2008 | 04:33 PM
cossiegreg1's Avatar
cossiegreg1
what colour is smoke? are you losing any water? what car?
Old Oct 20, 2008 | 04:42 PM
smerth54's Avatar
smerth54
its a fiesta rs turbo, its just normal smoke colour lol nah my waters been fine and i looked 4 mayo and there was none, which colour smoke mean what then?
Old Oct 20, 2008 | 04:51 PM
LHD220Turbo's Avatar
LHD220Turbo
if it the smoke is white'ish it could well be h/g
if the smoke is blue'ish, its likely oil related
if the smoke is black its likely to be fuel related
Old Oct 20, 2008 | 05:04 PM
smerth54's Avatar
smerth54
oh rite ok then well it does smell of oil tho
Old Oct 20, 2008 | 05:15 PM
smerth54's Avatar
smerth54
ive come with a random theory tell me im stupid if it is?
but could the fact that one of the lifters isnt lifting right cause it to smoke?
Old Oct 20, 2008 | 05:22 PM
LHD220Turbo
if it smells of oil i expecting it might be burning a bit; it could be piston rings or it could be turbo oil seals
is there much play in the shaft?
Old Oct 20, 2008 | 06:28 PM
smerth54's Avatar
smerth54
in which the turbo or the bottom end?
Old Oct 20, 2008 | 06:30 PM
mark r's Avatar
mark r
Default oil
the turbo,check it for up down side to side movement and it aint the bottom end that would be noisey real noisey
Old Oct 20, 2008 | 06:31 PM
LHD220Turbo
turbo
Old Oct 20, 2008 | 06:34 PM
smerth54's Avatar
smerth54
ok, would it still boost fine tho if it was this?
Old Oct 20, 2008 | 06:45 PM
LHD220Turbo
yeah
i mean this in the nicest possible way; but can you take it to a half decent mechanic to diagnose the problem or take it for a set up
Old Oct 20, 2008 | 06:59 PM
smerth54's Avatar
smerth54
yeah
ok then m8 cheers for your help
Old Oct 20, 2008 | 07:21 PM
rst in breaking's Avatar
rst in breaking
if you want im around your way at some point over the weekend but i could give it a compression test etc and test the rings for you and try and identify if its seals, gasket etc
Old Oct 20, 2008 | 10:41 PM
smerth54's Avatar
smerth54
ill have to let u know if im about this weekend but it would help out a gr8 deal cheers m8y
Old Oct 21, 2008 | 03:27 PM
cossiegreg1
what ever you do dont let him drive it. look at his sig to the last one he borrowed.
Old Oct 21, 2008 | 04:12 PM
smerth54's Avatar
smerth54
lmao yea ill keep that in mind lol
Old Oct 21, 2008 | 04:17 PM
GUZZLER's Avatar
GUZZLER
when does it smoke? on idle, on boost, on over run?
Old Oct 21, 2008 | 04:28 PM
smerth54's Avatar
smerth54
it never smokes on boost its when i idle then slow down 4 a turnin and when im sittin there
Old Oct 22, 2008 | 04:30 PM
smerth54's Avatar
smerth54
Old Oct 22, 2008 | 04:34 PM
haz87's Avatar
haz87
Its not just condensation due to the sudden cold streak of weather we're having is it (not taking the piss btw, the amount of people that suddenly worry at this time of year is higher than you'd think)
Old Oct 22, 2008 | 05:00 PM
smerth54's Avatar
smerth54
nope its not it stinks of oil lol so def not condensation
rst in breaking
it use to be my old car , but i broke it for spares, so never built the engine lol (and a crash werent the reson for breaking it )
Old Oct 22, 2008 | 05:11 PM
smerth54's Avatar
smerth54
lol, who every built the car back up doesnt like a full wiring set as its been chopped all the place aswell lol
JoeyBoyden
20
Aug 22, 2015 03:23 PM
220TC
13
Oct 25, 2004 11:22 PM
220TC
Oct 25, 2004 06:03 PM
simonc
Jul 24, 2004 04:46 PM
simonc
11
Jun 30, 2004 11:16 PM
