Changing springs
Old Feb 13, 2004 | 06:10 PM
Default Changing springs
Is it right you have to dislocate/remove the driveshafts to get them out/back in?
Old Feb 13, 2004 | 08:42 PM
B11GNS's Avatar
B11GNS
Thats how i done mine
Old Feb 13, 2004 | 09:07 PM
Only on the rear end. You don't have to remove them, just dislocate from either the hub or rear diff. Just don't let them hang down at extreme angles, support them with axle stands or something.
Old Feb 14, 2004 | 07:56 AM
Many thanks lads
Old Feb 14, 2004 | 08:11 AM
JamesH's Avatar
JamesH
Yep, thats how I did mine too
Old Feb 20, 2004 | 11:32 PM
i did'nt have a cosy but it was a 4x4 saff and i used cosy springs all i did was unbolted the rear beam and lowered it down on the jack just watch the rear brake lines i had a close call on my first try mined you find a garage that will do it for cash it should only cost £35 its alot easyer on a ramp
RS-Rikki
Sep 21, 2015 07:27 AM
marky_g
Sep 12, 2015 04:26 PM
Topjoe9
Sep 12, 2015 09:50 AM
truffleshuffle
Sep 10, 2015 09:35 PM
Adam Graham
Sep 6, 2015 06:04 AM
