Water temp problem
Old Oct 19, 2008 | 02:41 PM
declan morris's Avatar
declan morris
Default Water temp problem
Noticed this morning that the water in my 2wd saph is bubbling out of the header tank. When it gets warm the water stops flowing from the pipe from the turbo and seems to be coming back through the pipe from the pump. Has this happend to anyone before or does anyone know what could be the problem.
Old Oct 19, 2008 | 02:51 PM
declan morris
Plus the fans are not coming on when hot.
Old Oct 21, 2008 | 07:16 AM
declan morris
Anyone with any ideas.
Old Oct 21, 2008 | 09:37 AM
cozmeister's Avatar
cozmeister
More boost Igor!
There's a lot of overheating and temp gauge problems recently..must be something in the water.
Sounds like the thermostat's not opening perhaps? They don't cost much (an 88 degree one's only a tenner) and are reasonably easy to change, so you might be as well doing that - you can also test yours while its out
DixieTheKid
11
Jun 6, 2020 11:20 AM
15
Oct 7, 2015 03:43 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
Ben26
Sep 3, 2015 07:55 PM
