Possible gearbox rebuild?
Old Oct 18, 2008 | 09:11 PM
Turbo-Beal's Avatar
Turbo-Beal
Default Possible gearbox rebuild?
When i put my motor into first every once in i while it pops out of first gear when trying to pull away?
Its doesnt feel as positive as the other gears when selecting either.
I have fitted i b&m quick shifter and the gearbox was unused for a couple of years.
I guessing it could be the sincro but any sugessions would be greatful. Cheers
Old Oct 18, 2008 | 09:44 PM
studabear's Avatar
studabear
iirc baulk rings are worn, these hold it in gear
rebuild yes
Old Oct 18, 2008 | 10:19 PM
zvhturbo29rs's Avatar
zvhturbo29rs
Default rebuld?
has it only happened since fitting the b&m?? check its set up correct.linkage ect
Old Oct 19, 2008 | 08:17 AM
Turbo-Beal's Avatar
Turbo-Beal
I have never had a chance to test the gearbox before so i dont know
Its the only thing that hasnt been tested, rebuilt or replaced in the intire car so ill be gutted if its knackerd
Will it destroy the gearbox if i use it for a while to run in the engine?
Any idea what a rebuild would cost?
Old Oct 19, 2008 | 11:29 AM
addiction's Avatar
addiction
Mine has been doing the same ocasionally for the last few years and has not developed into any further problems!! if it only does it now and again i wouldnt be that bothered by it!!
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Mc5506
Oct 5, 2015 09:57 PM
Iain Mac
Sep 30, 2015 09:39 PM
