cvh head
right all being offered an xr2 head to replace my tired rs turbo head.can i swop these or doi need another rs head or are all cvhsthe same?need to know asap cheers all
orion=mini saff
RST has sodium filled valves,so there different in that sense,but it will work,used std heads b4 never had a problem,sodium filled valves are a bit over rated lol
Bodybuilding
From: Cannot be identified by the information given.
lean burn heads have the heart shaped combustion chambers and smaller inlet ports it will knock the compression up because of this so you will have to keep the boost down to stop the det
orion=mini saff
S2 were sodium filled,S1 and fez turbos wernt.
wht you changing a second hand head for another??
might aswell take yours off,have all all cleaned up,valves re lapped,re face and stick it back on,be good as new
mk3ste
Oct 17, 2021 10:09 AM
Mc5506
Oct 5, 2015 09:57 PM
