cosworth top end knocking noise
Old Oct 16, 2008 | 04:10 PM
cozi500's Avatar
cozi500
Default cosworth top end knocking noise
my cosworth has a top end knocking noise, when dropping off the revs, sound like a follower sticking, but since replaced these. but still there. its had new pistons, rings, crank, shells, hp oil pump, 80 psi when cold, 30 psi when at normal opperating temp. took to pj motorsports yesterday but after a long run there the noise had almost vanished. they said it sounded a bit cami but checked timing and was ok, could it be little ends!!!
Old Oct 16, 2008 | 04:20 PM
cozmeister's Avatar
cozmeister
More boost Igor!
I'd be tempted to say piston slap if it were 2wd, and did it when it was cold...
Old Oct 16, 2008 | 05:27 PM
cozi500's Avatar
cozi500
just had rebore and new pistons / rings, and noise is from top end.
Old Oct 16, 2008 | 05:33 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Rules piston slap out then
IAN RS2k
Aug 18, 2015 07:51 PM
Aug 14, 2015 07:29 AM
Roosie
Aug 13, 2015 07:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
Bezzy41
Aug 3, 2015 10:31 AM
