Pro Alloy Intercooler fitting problem
Old Oct 16, 2008 | 08:01 AM
S2_RST_DK's Avatar
S2_RST_DK
Default Pro Alloy Intercooler fitting problem
Hi
Trying to fit the Pro Alloy intercooler on a S2 (the kit with two small fans) and it seems like i have to move the radiator 5 mm towards the turbo, otherwise the intercooler will not fit correctly.
Has anyone else had that problem and how did you fix it ??
Does anyone have a pic of the top bracket mounting ??
Henrik
Old Oct 16, 2008 | 10:49 PM
Bryan_RST's Avatar
Bryan_RST
Default intercooler
hi there i fitted my one about 1 mouth ago and i did need to move the rad back a bit to get it to fit good thanks bryan
Old Oct 17, 2008 | 07:35 PM
marky_g's Avatar
marky_g
Fleet Manager
sounds normal mate, not a direct fit
Old Oct 17, 2008 | 07:41 PM
S2_RST_DK's Avatar
S2_RST_DK
I know you can move the bottom part of the radiator back a bit, making 2 smal brackets.. BUT the top part of the radiator, how do you move that back ???
Henrik
Old Oct 17, 2008 | 10:59 PM
Red_bull's Avatar
Red_bull
think you're trying to get the fans between the IC and the rad? I had the same problem and i think the intercooler has to be as much as you can to the bumper and the rad then so far as you can to the turbo...
I mounted the fans on the front of the IC
cossynut2
Aug 19, 2015 11:29 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Caddyshack
15
Aug 4, 2015 08:50 AM
