rs turbo head pics what caused this ???
Old Oct 14, 2008 | 10:09 PM
fatboyz's Avatar
fatboyz
Default rs turbo head pics what caused this ???
here are a few pics of a mates car bar his driving what would have caused this
really pitted where the metal ring of the head gasket sits
cheeRS
Old Oct 14, 2008 | 10:15 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
just looks like carbon deposits in the pics.scrape it off using the flat of a stanley blade,then have another look.
Old Oct 14, 2008 | 10:30 PM
fatboyz's Avatar
fatboyz
just give it a quick scrape uploading pics now
Old Oct 14, 2008 | 10:44 PM
fatboyz's Avatar
fatboyz
Old Oct 14, 2008 | 10:52 PM
The Youth.'s Avatar
The Youth.
is it not det eating the alloy head?
steve
Old Oct 14, 2008 | 10:55 PM
xr4x4rs's Avatar
xr4x4rs
could just be normal pitting that happens in alloy, looks like he needs antifreeze though
Old Oct 14, 2008 | 11:08 PM
Lloyd's Avatar
Lloyd
ive not seen a running engine that bad before, looks like its been stood for years,and the water( without antifreeze ) has gone from the waterway to the fire ring,and corroded the head,what was the gasket like?
pics can be deciving,but that doesnt look like it will skim out.
can you get det under the fire ring?i would have expected a lot more damage around gap between the valve if it was caused by det.
is it just the one cylinder that has the problem?
Old Oct 14, 2008 | 11:46 PM
fatboyz's Avatar
fatboyz
the engine had been stood for a while then fitted to a mates car only water put in the engine then but it was only on the road for a while ( 3 weeks ) then after a bit of a nailing one day he parked up then restarted but it was smoking real bad with a misfire and it was down on compression on number 3 which has the worse pitting , the gasked looked ok it was quite pitted on edge of valve and it was a bit pitted on all but real bad on 2 even worse on 3
Old Oct 15, 2008 | 08:20 AM
fatboyz's Avatar
fatboyz
any ideas peops
Old Oct 15, 2008 | 08:30 AM
fatboyz's Avatar
fatboyz
no i dont think it will skim out either its really deep
Old Oct 15, 2008 | 11:09 AM
thebigyin's Avatar
thebigyin
Originally Posted by fatboyz
any ideas peops
its fucked.
Old Oct 15, 2008 | 11:22 AM
fatboyz's Avatar
fatboyz
Originally Posted by thebigyin
its fucked.
uh huh we know this but any idea what caused it
Old Oct 15, 2008 | 01:08 PM
xr4x4rs's Avatar
xr4x4rs
as already said, the engine has been sat for some time
alloy tends to corrode over time, will it can start in a couple days if left in damp conditions
Old Oct 15, 2008 | 01:10 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
What head gasket was it?
Old Oct 15, 2008 | 01:14 PM
T3ORA's Avatar
T3ORA
look's like someone fitted a head gasket before and not had the head skimed
Old Oct 15, 2008 | 01:17 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
steve
you are correct
detonation is the cause
Old Oct 15, 2008 | 01:45 PM
fatboyz's Avatar
fatboyz
hi just standard as far as i know
Old Oct 15, 2008 | 01:47 PM
fatboyz's Avatar
fatboyz
we took the engine out of a running car and fitted it into a mk4 estate without doing anything to the engine
, but thanks for the input
Old Mar 16, 2014 | 11:21 AM
Paul_RS's Avatar
Paul_RS
HOLY 2008 BATMAN!!!!!!!!!!
Old Mar 16, 2014 | 11:23 AM
RSmark84's Avatar
RSmark84
I know the post above yours is just spam. link leads to nowhere.
Old Mar 16, 2014 | 11:38 AM
Rsturbo519's Avatar
Rsturbo519
http://s158.photobucket.com/user/bla...bile%20Uploads
Old Mar 16, 2014 | 11:41 AM
Rsturbo519's Avatar
Rsturbo519
Sorry about the above link leading no where, what do you think my gasket failure was caused by?
Old Mar 16, 2014 | 11:55 AM
RSmark84's Avatar
RSmark84
Wrong link:
Old Mar 16, 2014 | 03:53 PM
Karl's Avatar
Karl
Norris Motorsport
There can be many causes of head gasket failure, the usual being block or head faces that are not completely flat (this includes localised low spots such as between cylinders on blocks), cylinder head lift due to inadequate head bolt clamping, abnormal running conditions such as detonation or extermely high temperatures, and of course the use of substandard headgaskets and components.
I cannot comment on any of the above problems on your engine, except to say you are using a very low quality head gasket, so that alone could be your problem. Use a genuine Ford/Payen head gasket and see how it goes. If it blows with that fitted you have one or more of the issues Ive listed above!!
Old Mar 16, 2014 | 04:08 PM
Rsturbo519's Avatar
Rsturbo519
Thanks Karl, I thought that was a Payen gasket that I have got?
Old Mar 16, 2014 | 05:56 PM
Karl's Avatar
Karl
Norris Motorsport
If it is a payen its certainly not an RS turbo one.
big_Rad
Sep 15, 2017 09:36 AM
3i Jim
Nov 20, 2015 05:12 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
IAN RS2k
Aug 18, 2015 07:51 PM
