Home audio visual dudes - new amp?
right i am looking into buying a new home cinema amp, looking at spending 400 ish quid, was thinking of maybe the Onkyo 606, any thoughts?
I think this looks ok, it supports up to 7.1 sound and also the dolby digital and true hd formats so you are compatible with the latest sound formats. The only downside is there is only two optical in connections although it does offer 4 hdmi inputs.
http://www.richersounds.com/showprod...KY-TXSR606-BLK
The Pioneer and Yamaha amps are very good, ive owned both, i have to say the Pioneers VSX1017 av amp is incredible, its in www.richersounds.co.uk at Ł349.95.
Or if you can afford one Rotel and NAD make very good av amps too, but if it was my money id have the pioneer.
Hope this helps
Hope this helps
personally i'd go for the brand new yamaha dsp-ax763 model at around Ł350, its a brand new 2008 model and is supposed to be excellently specced and has had some rave reviews.
only drawback is it only has 2 HDMi inputs, but they are the 1.3 version that carry audio as well if needed (some dont).
this is the amp i will be looking to get in the next few months
regards
rory
regards
rory
I'm speccing a system up at the moment too. I've looked around at a load and will probably be going for the Onkyo 606 as well.
Other similar priced units don't have as many HDMI inputs [onkyo has 4]...
1. PS3
2. Sky HD
3. DVD/CD player - for her to play DVDs on without fucking up my PS3 and CDs without having to turn the TV on to see what track you're at.
4. Future expansion, projector maybe?
I don't know a lot about all this stuff but the main competitors around Ł400 seem to be the Denon 1909, the Yamaha AX763 and some of the Sony gear.
I don't know the full specs of the others to fully compare but the 606 does use HMDI 1.3 as said above and also upscales other inputs to 1080i.
1. PS3
2. Sky HD
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
