heated front screen
Oct 14, 2008 | 06:11 PM
heated front screen
is there a common fault with the heated front screen on frst's cos mine wont work Ive tried everything i can think of even changed the switch any ideas?
Oct 14, 2008 | 06:14 PM
Just use logic and follow the route, could be something simple like a broken connection.
Oct 14, 2008 | 06:26 PM
are the reminals to the screen both connected? as ive often seen them broken
Oct 14, 2008 | 06:39 PM
Quote:
Originally Posted by
rst in breaking
yea they both seem fine only thing i can think of is that when i put the piller bit back on im knocking them back off again?
also the switch doesn't stay in like the other 4 do?
Oct 14, 2008 | 06:41 PM
try a pwer probe on it poss and work out what is and what isnt working?
Oct 14, 2008 | 06:48 PM
yea ill have 2 buy one or borrow one off my mate but ill give that a go
thanks
Oct 14, 2008 | 07:01 PM
What about the earths at the top of the screen behind the rear view mirror?
Oct 14, 2008 | 07:07 PM
Far more likely that one or more of the strands are broken inside the screen. I see it all the time, very common
Oct 14, 2008 | 07:10 PM
so if one of the strands are broken in the screen that would stop the whole thing working? could a chip cause this?
Oct 14, 2008 | 08:57 PM
I would do a continuity test on the screen. Like tabetha said and just follow the route. Not much too them to be honest
Oct 15, 2008 | 12:21 AM
yea i did think about this but its abit hard when it goes behind the dash?
Oct 15, 2008 | 01:27 AM
The wiring plugs in to a connector near the stereo (Round the back of the wiring harness, so cannot be seen if looking straight on. You need to pull it round!
Oct 9, 2015 07:38 PM
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
C2 MAK
Aug 20, 2015 09:46 PM
check ,
fault ,
faults ,
faulty ,
fiesta ,
focus ,
ford ,
fordfocus ,
front ,
frontscren ,
heated ,
plug ,
screen ,
work
