s2 nightmare
Old Oct 14, 2008 | 04:28 PM
Korda's Avatar
Korda
Default s2 nightmare
after paying good money for a 1988 s2 rs turbo in rosso red only 91,000 miles loads of history mods. its been sat up for 3 weeks. called the aa out to find out my fuel pump and metering unit fucked. after some time sorceing parts i fitted the new metering unit and pump. started it up today runs lumpy but nice to here it running.so its off to be set up tomro. cant wait to drive it. its got bayjo chip, stage one turbo, 31 act, boost control, samco hoses, balley dumpvalve, some crome parts, new s/s exhaust from turbo, fitted a cossie fuel pump, oil, water, boost,volt, gauges,
17, inch momo arrows, uprated discs and pads, konis alround, rs 3 spoke sterring wheel, what sort of power should i see
Old Oct 14, 2008 | 04:43 PM
5t1g's Avatar
5t1g
Shotgun Bunter
160bhp? still on standard intercooler?
Old Oct 14, 2008 | 05:13 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
yea I would expect to see 150 - 160 bhp
Old Oct 14, 2008 | 05:43 PM
Korda's Avatar
Korda
got a pace intercooler in
Old Oct 14, 2008 | 06:15 PM
Turbocabbie
Top Cab !!
I would expect 160 maybe a little bit more.
Old Oct 14, 2008 | 06:21 PM
sidewaysdave's Avatar
sidewaysdave
mines roughley the same spec and it made 182.3
Old Oct 14, 2008 | 06:34 PM
Korda's Avatar
Korda
what step should i look at next cams pulleys
Old Oct 14, 2008 | 07:00 PM
bigryrs's Avatar
bigryrs
RSHoleinator
sounds nice mate any piccies
Old Oct 14, 2008 | 07:01 PM
Korda's Avatar
Korda
how do i get them up loaded
Old Oct 15, 2008 | 08:03 AM
Turbocabbie
Top Cab !!
I would look at ported head and cams before cam pullys and a decent front mount, dump that pace
Old Oct 15, 2008 | 08:04 AM
Turbocabbie
Top Cab !!
you have to upload them to a picture hosting site such as imageshack and then post the url to that image as follows
[img]imageurl.com/picture.jpg[/img]
Old Oct 15, 2008 | 10:06 AM
Korda's Avatar
Korda
what cams would be best and intercooler, what do you thing about zvh 1.8. uprated pistons iv been told they use calibra turbo pistons
Old Oct 15, 2008 | 10:21 AM
grayzo's Avatar
grayzo
grayzo
id say 170 180 ish my mates s1 has standard turbo and cooler set up by norris and was 170 odd horses
Old Oct 15, 2008 | 10:22 AM
grayzo's Avatar
grayzo
grayzo
the calibra pistons will fit the 2 litre zetec far easier
Old Oct 15, 2008 | 11:08 AM
Korda's Avatar
Korda
sounds good thanks for all your help. just need to sorce all parts,
Old Oct 15, 2008 | 12:46 PM
Korda's Avatar
Korda
after all the car wont start paid to tuned called them back out cant get it going. iv cheaked the cold start valve. put new pump and meter unit in. had timeing done. changed plugs leads, diz rota arm. what could it be
Old Oct 15, 2008 | 05:31 PM
5t1g's Avatar
5t1g
Shotgun Bunter
have you got a spark? ECU sometimes go on them
5t1g's Avatar
5t1g
Shotgun Bunter
You've not got an after market alarm have you?
Old Oct 15, 2008 | 06:38 PM
roro22's Avatar
roro22
I have a radtec front mount intercooler for sale PM me if you are interested
Mine has -31 act, piper cams, stage 1 chip, magnex system, air filter, radtec front mount at 12ppsi boost its making 155 at the wheels so I would think you would be about that
Old Oct 15, 2008 | 07:24 PM
Korda's Avatar
Korda
got a spark runs for 3 secs then cuts out could the imobiser be cutting in
Old Oct 15, 2008 | 07:25 PM
Korda's Avatar
Korda
yes full alarm system
Korda's Avatar
Korda
yes belled up
Old Oct 16, 2008 | 12:10 PM
5t1g's Avatar
5t1g
Shotgun Bunter
Imobilser sounds likely
Old Oct 17, 2008 | 07:50 PM
marky_g's Avatar
marky_g
Fleet Manager
same spec as mine and mine made 186bhp at 1bar
i have since swapped for airtec front mount and am looking at a Newman cam, don't go solid lifters tho there a bastard to adjust
Kyle Langford
27
Aug 5, 2019 07:54 PM
pabloXR
Sep 21, 2015 12:42 PM
JamesH
Sep 2, 2015 10:02 AM
Mark 3D
Apr 11, 2005 08:49 AM
Redeye Jedi
Mar 14, 2005 09:20 AM
