Where is the airbag ECU on a 99 Fiesta?
Old Oct 14, 2008 | 01:32 PM
johnhara1's Avatar
johnhara1
Default Where is the airbag ECU on a 99 Fiesta?
As title.
Airbag deployed, i need to know where the airbag ECu is located so i can replace it and put new airbag on.
John
Old Oct 14, 2008 | 01:40 PM
RichieST's Avatar
RichieST
Pretty`sure its mounted under the plastic centre console just infront of the handbrake
Old Oct 14, 2008 | 01:56 PM
johnhara1's Avatar
johnhara1
Thank you.
Old Jan 14, 2009 | 09:45 AM
johnhara1's Avatar
johnhara1
Incase anyone else browses this, theres an access panel inside the glove box.
It's in there.
You need to remove the plastic on the dash where the pass airbag would be to get the ECU out.
TPM961
Jan 15, 2018 10:50 AM
liamT74
Sep 23, 2015 10:24 PM
dave1960
Ford Fiesta
Sep 16, 2015 11:34 PM
DixieTheKid
Sep 14, 2015 09:04 PM
