removing a engine with out a crain? --:: HELP ASAP! ::--
Old Feb 13, 2004 | 09:58 AM
Default removing a engine with out a crain? --:: HELP ASAP! ::--
as above its only a 1.3 if not any 1 no were i could hire 1 from ??
Old Feb 13, 2004 | 10:27 AM
PJay's Avatar
PJay
depends on what car, with 2 of ya it can be done if your not a weakling
Old Feb 13, 2004 | 11:04 AM
its a escort mk4 1.3 and there will probly b more than 2 thanks pjay
Old Feb 13, 2004 | 11:13 AM
PJay's Avatar
PJay
No probs then matey
Old Feb 13, 2004 | 05:19 PM
Uncle Henry's Avatar
Uncle Henry
Just get the front of the car as high as possible on blocks etc then drop the engine out the bottom on a trolley jack. easiest way.
engine cranes can be hired cheaply enough from any hire shop.
Old Feb 13, 2004 | 05:47 PM
easy peasy!
NO PROBLEM!!!lol i know it doesnt have a head on top of the engine but would only require lifting the car up another 30cm or so, not a problem with blcoks of wood!
and gearbox was still attached to...engine needs to go in the bin now, getting in the way!
hope that gives you an idea matey!
Old Feb 13, 2004 | 08:01 PM
nice 1 mate, wat u use to drop the engine down??
as it is goin to be 1.3 engine+gearbox
Old Feb 13, 2004 | 08:40 PM
forgot to mention i need an answer from any 1 asap as the car im tkin engine from has to be gone by monday!
Old Feb 13, 2004 | 11:22 PM
PJay's Avatar
PJay
Personally i would NEVER raise the front of a car like that
Old Feb 14, 2004 | 05:26 PM
how do i get the drive shafts out??
Old Feb 14, 2004 | 05:30 PM
PJay's Avatar
PJay
Take the nut off the TCA and use a ball joint seperator to pop the joint and then just pull the hub and strut till the shaft pops out
manuel boeckx
13
Oct 3, 2015 02:29 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Aug 29, 2015 08:16 PM
track.focus'd
Aug 12, 2015 05:53 PM
MARKYMARKONE
Aug 2, 2015 09:33 PM
