zetec turbo help
Old Oct 13, 2008 | 11:54 AM
performace_ford's Avatar
performace_ford
Nae Bither!
Default zetec turbo help
can anyone help
i have been told that a focus st170 water pump will fit my silver top zetec e ????
what inlet to use???
injectors???
flywheel???
clutch???
also is it the 2wd cosworth brakes that fit the mk3 escort???
do i have to change the valves as well as the valve springs???
what management to use and who will set it up???
what are standard erst driveshafts capeable of???
just looking for about 240-280 bhp
any info would be great cheers
Old Oct 13, 2008 | 12:10 PM
RS 5tu's Avatar
RS 5tu
http://www.fiestaturbo.com/articles/zetecturbo/
that will help.
Cheers Stu
Old Oct 13, 2008 | 04:02 PM
performace_ford
Nae Bither!
is it safe enough to leave the crank the way it is? for a 240 bhp zetec turbo?
also any1 know what standard erst shafts are capeable of?
also would any 1 know if the windows and rubbers are the same in the mk3 and mk4 escorts please???
Old Oct 13, 2008 | 05:48 PM
gtit's Avatar
gtit
bn told the standard crank can take 500 bhp, has anyone else heard this?
Old Oct 13, 2008 | 05:53 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It's true..
Old Oct 15, 2008 | 09:10 AM
performace_ford
Nae Bither!
is the focus st 170 water pump a direct re-placement on my silvertop??
will a focus rs clutch work on rs1800 flywheel and s1 box?? if not any suggestion to run rs clutch??
is focus rs spark plugs exact same as normal zetec ones??
Old Oct 15, 2008 | 10:04 AM
Windle's Avatar
Windle
no the st170 waterpump is from the black top engine and the "hole" is much smaller than an earlier silver top? Also will still spin the wrong way unless you have another pulley setup in there
Old Oct 15, 2008 | 01:15 PM
performace_ford
Nae Bither!
cheers for the reply so does the water pump have to be uprated ?
Old Oct 15, 2008 | 03:20 PM
performace_ford
Nae Bither!
has anyone heard of using nissan pulsar pistons in a zetec???
does it work??
Old Oct 15, 2008 | 04:31 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It may be a good idea to approach an experience zetec turbo engine builder.. your head is full of internet rubbish!
Old Oct 15, 2008 | 05:14 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
best advice i've heard
Old Oct 15, 2008 | 05:19 PM
studabear's Avatar
studabear
also if ur puttin a full zetec in then surely it would be as easy to use the zetec water pump, iirc if using a 2000cc you need the 1800cc pump
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
