My s2 is getting very hot dont now why ?
Old Oct 12, 2008 | 11:43 PM
NICK321RS's Avatar
NICK321RS
Default My s2 is getting very hot dont now why ?
my s2 is running very hot when ticking over just dont now why
as far as i now the head gasket is not gone and the fan is kicking as and when it should
its fine all the time your driving it but when your in traffic goes in to the red
can any one help me sort this ?
Old Oct 13, 2008 | 12:01 AM
rst230bhp's Avatar
rst230bhp
I would probably start by bleeding it to release any air trapped, i normally do this by starting the car up from cold with the header tank cap off leave heater on 1 let it warm up once up to temp squeeze the water hose a few time should see bubbles appearing in the header tank wait till fan kicks in and cools it down.
if this dont work i would probably change the thermostat, u might as well change the fan switch as its not much.
is it the car in our sig coz it looks a beauty
hope you get it sorted
Old Oct 13, 2008 | 10:32 AM
Smartdj.'s Avatar
Smartdj.
could replace water pump...i would never even let mine get near the red tbo
Old Oct 13, 2008 | 11:56 AM
RSTurboSI's Avatar
RSTurboSI
as two above,
Air the system, go pop the kettle on and boil it while ur making urself a cuppa pop some in a bowl and put ur thermostat in, should open, I just repalced mine. Check water pump is working fine and if not change that, think when i did my water pump while i had my engine rebuilt it was something like 40-60 pound. not that exspensive.
also change the fan plug.
I run my fan on switch as the fan plugs tend to frie and stop working. just a switch in the dash so once its a bit warm. say 1/4 warm and im town/traffic driving ill switch it on. i wouldnt bridge the fan so its on all the time as it may undercool and thats just as bad.
That heat Sheald aswell,that chrome RSTURBOone. Get rid of that while driving the car, they hold so much heat.. i also removed the plates under the grills on the bonnet to push more cool air in and out the top of the bonnet.
Other thing, Bonnet lifters work..
nice car tho..
Old Oct 14, 2008 | 12:01 AM
NICK321RS's Avatar
NICK321RS
thanks for the comments i dont have a thermo stat in it at the mo and its just had a new water pump
i may be thinking that my fan is not spinning quick enough i got hold of a s1 fan today and it spins so much faster but also i have just ordered twin 9 inch fans for it hope this works
Old Oct 14, 2008 | 03:57 AM
tejy's Avatar
tejy
im having the same problem..my head gasket hasnt gone tho..i changed the temperature sensor unit to see if that was the problem but it still goes wayy up to the top. im considering buying a new radiator? how do i know wen the fan kicks in btw?
Old Oct 14, 2008 | 04:23 AM
paceo's Avatar
paceo
why no thermostat? your fan is kicking in normally with no thermostat? is it a manual swith for the fan you have then?
Old Oct 14, 2008 | 07:54 AM
Dave_RS's Avatar
Dave_RS
About a year ago i have the same problem runing on 90ş and on red lights the clock just go up extremely fast, i just cleaned the radiator, changed for the 82ş thermostat and uprated to a NMS fan swith (93/90)... Now i don´t see any readings up to 94ş on my temp gauge... and that´s quite good on hot summers down here on Spain!
Old Oct 14, 2008 | 10:27 AM
RSTurboSI's Avatar
RSTurboSI
normaly half way i think.
i have an rad standard RS one im in notts tho so you'll have to travel but u can have it for nothing mate
i dont understand that, how can u not have a thermo and ur fan kick in?.
Old Oct 14, 2008 | 06:38 PM
sidewaysdave's Avatar
sidewaysdave
i had the same problem and have changed the rad, water pump, thermostat, replaced all the hoses and the head gasket it ended up being the core plug below the dizzy had rotted through and was leaking slightly
Old Oct 15, 2008 | 12:45 AM
rst230bhp's Avatar
rst230bhp
same here mate you would need a thermostate for the fan switch to activate and fans to cut in
Old Oct 15, 2008 | 02:19 AM
babscossie's Avatar
babscossie
Why????
Old Oct 15, 2008 | 03:04 AM
Dave_RS's Avatar
Dave_RS
For start the fan you only need a fan swith... and it´s mounted on the thermostat housing. With or without thermostat inside the housing you can have a fan swith.
Old Oct 15, 2008 | 07:58 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
as above ,i took my thermo out and fan still cut in
Old Oct 15, 2008 | 11:55 PM
rst230bhp's Avatar
rst230bhp
well you learn somthing new everyday, ill have one of these
Fiddy
21
Sep 29, 2015 06:10 PM
PeterLucas
Sep 21, 2015 11:36 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
