saw exhaust temp of 880 c at 167
Oct 12, 2008 | 11:09 PM
my egt sensor is in the downpipe bout 2 inches behind the turbo and saw peak temp of 880 c after blasting about and then 167, im worried if fuel pump is struggling abit at top end
should i be worried ?
Oct 12, 2008 | 11:14 PM
sounds ok to me for a top speed run
Oct 13, 2008 | 11:01 AM
Quote:
Originally Posted by
leecavturbo
what peaks do you see ?
Oct 13, 2008 | 11:06 AM
It's too hot really for a non-247 turbo. You'll only know if the fuel pump is struggling if you put a fuel pressure gauge on it and monitor.
Oct 13, 2008 | 11:11 AM
pa_sjo
i may have to get one or a afr monitor. if it is running running lean at the top that would cause increased exhaust temp wouldnt it ?
Oct 13, 2008 | 11:14 AM
Passionford Thread Killer
scoooby slayer
Would of thought so yes, but if that temps about right for a 167 run then no.
Surely some of the MAD boys would know the sort of temps you can expect to see?
Oct 13, 2008 | 11:15 AM
For the sake of £45 if you havent done it already is buy the rewire kit for the fuel pump coswurv on here has got one im sure
Oct 13, 2008 | 11:18 AM
scoooby slayer
Yes, running lean will usually increase EGT. So will running the ignition too retarded. So will excessive TIP. So will lots of things
If the compression ratio is low enough, the ports big enough, the turbo big enough and the mapping right, you shouldnt have an issue
Carlo , I think he more talking about fuel pres. than the voltage to the pump.
Oct 13, 2008 | 11:19 AM
pa_sjo
TIP????
Cool just thought that every little helps
Oct 13, 2008 | 11:21 AM
carlo
well I hope he's not still on the std 20yr old pump loom with that spec under the bonnet.
Oct 13, 2008 | 11:22 AM
highest it used to see was 820 c few months ago then gauge started dicking about so just put new sensor on and saw 880 c
the only thing thats changed since it was mapped is the map sensor as it failed.
Oct 13, 2008 | 11:23 AM
loader5710
na mate 044 and rewired
Oct 13, 2008 | 11:27 AM
Afr gauge then to be safe.
Oct 13, 2008 | 11:41 AM
Is it the same sensor as before? The gauges and sensors are usually matched to each other. If you used a different make sensor then it will give a different reading on the gauge.
Oct 13, 2008 | 12:41 PM
Rich170
yeah its identical sensor
Oct 13, 2008 | 04:36 PM
had some massive flames every time i let of the throttle would it not do this if it was running lean ?
Oct 13, 2008 | 04:39 PM
why have you got an EGT gauge without an AFR gauge?
surely the results of EGT are so reliant on AFR that you need to look at them together in context?
Oct 13, 2008 | 04:52 PM
scoooby slayer
The parts of the map (and the transient control strategies) when you lift off the throttle are nowhere near the parts of the map when you're flat out, so unrelated completely.
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
