escos track day today raf marham with pics
had a track day today at raf marham .
escos was running well allday - long enough straight to acheive top speed of 160mph at 6000 rpm ! - runs greys,t4,swedish inlet, 70 mm throttle body , ported head , 28 psi boost
got through a set of front tyres as well , worn to the cords - bugger!
had a very slight engine fire at end of last session , it was open pit lane at the end of the day so i stayed out for 40 mins with the hope of doing 5 quick laps , 5 cooling down laps , but ended up doing 40 mins of driving like i stole it .
either manifold heat wrap , or oil leak onto down pipe , happened as i parked up after session so luckily i put it out straight away - no damage
drove home fine so will check it out up the workshop in the week
will have to get big brakes next to make the most of the package
got it cleaned off today , fire did no damage .
looks like oil leak might be from headgasket though ! bugger - had the block & head refaced when i built it 1500 miles ago .
steve -had the escos for 2 yrs , used to have a black saph on gold 17's you may have seen or my purple mk2 escy .
thanks for the comments peeps ! means alot when people say they like it , as you all will know
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
