S2 blowing out spark when on high boost, why???
The posh are up!!!
as above when im on high boost it holds back and slutteres misfires, been told it blowing out spark, what can cause this, i got std plugs gapped to 0.7 with group a coil?
The posh are up!!!
harvey tried this but then on light throttle it would misfire, but boost fine with a bit of misfire. so i opened the gap to point 7 it cured the light throttle side of it, but now the problem with high boost
Mine used to blow the spark out on full boost @ very high rev's and i was running Denzo iridium's or what ever there called lol And there supposed to be good! Changed to a set of good old 701's and its been fine since
Mark RS
Oct 12, 2015 06:01 AM
deathrider666
Sep 28, 2015 06:12 PM
