siemens injectors , what did you do to your fuel rail ??
fitted mine to the es cos yesterday
they are shorter than bosch ones i think and only just fit if you leave the o rings visible
anyone else had this and what did you do ??
I thought they were a direct replacement.
Make sure you lightly oil the O-rings then attach the rail, then as you bolt the rail to the plenum the rail will push itself into place on the injectors. You'll need to wiggle the injectors into place to make sure they're secured in the rail.
yes they are in but only just, i know scott had the same problem......
just look a bit dodgy to me ??
was thinking of modifying the fuel rail ?
shouldnt have to mod anything - mine went into a 2wd, and i assume you are fitting the injectors in to an escort cossie?
unless the fuel rail is different on an escos compared to a 2wd, there is no need to mod anything; direct fitment
PassionFords Creator
DixieTheKid
11
Jun 6, 2020 11:20 AM
timsrs
22
Sep 24, 2015 08:14 PM
