pectel t2 help!!!!!!!!!!!!!!!!!!!!
Old Oct 12, 2008 | 01:33 PM
rst-g's Avatar
rst-g
ZETEC TURBO
Default pectel t2 help!!!!!!!!!!!!!!!!!!!!
on the last stage of gettin the car started it turns over fine but I have no live to the coil pack the is one earth which is the center wire out of the 3pins the other 2 show nothink! What pin is the live on the ecu it's for a zetec turbo. I fookin hate cars LOL
Old Oct 12, 2008 | 02:39 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Pins 1 & 14 should be the ones on a T2...
Old Oct 12, 2008 | 02:40 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
pin 1 on the coil plug is ING1 pin1 ecu
pin 2 on the coil plug is live
pin 3 on the coil plug is ING2 pin14 ecu
hope this helps
Old Oct 12, 2008 | 02:42 PM
rst-g's Avatar
rst-g
ZETEC TURBO
just tryed them will and all I get on the power probe is a green flash- earth on both of them is that right? I thought they might of bin live.
Old Oct 12, 2008 | 02:59 PM
rst-g's Avatar
rst-g
ZETEC TURBO
which is the live on the ecu for the coil feed? as pins 1,14 are the earth's
Old Oct 12, 2008 | 03:05 PM
robp-tt's Avatar
robp-tt
ZETEC TURBO
pin 2 on the coil plug goes straight to feed(ing feed) and dosent go to the ecu(ive got 2 t2 looms infront of me and both go straight to feed)
Old Oct 12, 2008 | 04:51 PM
Big Will_'s Avatar
Big Will_
As said above - the central wire is the live and the outers are negative triggers from the ECU
Old Oct 12, 2008 | 05:20 PM
rst-g's Avatar
rst-g
ZETEC TURBO
I know the outers are triggers form the ecu but the is no live at all from the central pin
Old Oct 12, 2008 | 05:23 PM
Big Will_'s Avatar
Big Will_
The live isn't from the ECU - it's just an ignition live.
Old Oct 12, 2008 | 05:37 PM
rst-g's Avatar
rst-g
ZETEC TURBO
so if I put a wire from the battery to the coil it should start?
Old Oct 12, 2008 | 05:44 PM
Big Will_'s Avatar
Big Will_
If it's just to test it starts - make sure it's fused though!!!
Old Oct 12, 2008 | 05:46 PM
rst-g's Avatar
rst-g
ZETEC TURBO
sound thanks will!!!!!!!!!!
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
jay030787
Sep 25, 2015 01:38 AM
Steve Cooper
Sep 15, 2015 04:39 PM
muz
Aug 16, 2015 12:57 PM
