What are these turbo manifolds like from Norway?
Old Oct 12, 2008 | 08:37 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default What are these turbo manifolds like from Norway?
http://cgi.ebay.co.uk/Cosworth-16v-y...d=p3286.c0.m14
My 2wd one is looking a bit old thought i would look at getting a good tubilar manifold.
Any recommendations or reviews
Old Oct 12, 2008 | 08:59 AM
Garage19's Avatar
Garage19
Nice fab work but if you do go for one i would reccomend a serious turbo support.
I expect the manifold is only of 1.6mm tube so won't take the weight of the turbo bouncing up and down on it with all that heat for long before it fatigues and cracks.
Old Oct 12, 2008 | 09:01 AM
Roosie's Avatar
Roosie
do you reccomend anyone that can supply a good quality manifold? fairly quick
Old Oct 12, 2008 | 09:04 AM
Garage19's Avatar
Garage19
Primary designs? But they are £1100 ish??
Why not stick with your 2wd one? I ccan get it blasted for you if you like? That should tidy it up.
Old Oct 12, 2008 | 09:07 AM
Roosie's Avatar
Roosie
what is it just sandblasted?
Old Oct 12, 2008 | 09:16 AM
Garage19's Avatar
Garage19
Yes, just sand blasted.
You could always get it ceramic coated by zircotec?
Old Oct 12, 2008 | 09:39 AM
Roosie's Avatar
Roosie
whats the damage on getting it ceramic coated both parts of manifold
Old Oct 12, 2008 | 10:54 AM
jaimesdna's Avatar
jaimesdna
i painted mine with high temp black paint. sort of when grey with the heat (have had it glowing) but better than rusty brown.
Old Oct 12, 2008 | 12:24 PM
Garage19's Avatar
Garage19
I would have thought somewhere between £150 and £200.
Old Oct 12, 2008 | 12:35 PM
Roosie's Avatar
Roosie
bloody hell raped twice lol
Old Oct 12, 2008 | 04:02 PM
cossiemanden's Avatar
cossiemanden
DANISH cosworth abuser
http://www.randbmotorsport.co.uk/sho...p?ProductID=50
I know the guy who makes theese manifolds for mike, and they are proper goodies.
They have been developed on the dyno and gives wery little egt diff each cylinder wise and flow REALLY well.
If you want the best from your engine you shouldent spare anything on your manifolds, they make a HUGE difference
Old Oct 12, 2008 | 04:06 PM
Roosie's Avatar
Roosie
Are these the same as the ones on ebay or different maker?
Old Oct 12, 2008 | 04:11 PM
cossiemanden
Unless they aye used then no.
He dont sell them on ebay, he is to serious for that
Old Oct 12, 2008 | 04:14 PM
grcossie's Avatar
grcossie
Look here, these are great Norwegian made
http://www.mobeck.com/MT/Grenrorgalleri.asp
Old Oct 12, 2008 | 04:17 PM
cossiemanden
those are wery nice also
Old Dec 5, 2008 | 06:07 PM
BR racing V6's Avatar
BR racing V6
*edited - if you would like to advertise, feel free to pay the traders fees!*
Old Dec 17, 2008 | 10:48 AM
RickyLee53's Avatar
RickyLee53
Stainless steel welded onto a mild steel flange to stop cracking? Thats a new 1.
Old Dec 17, 2008 | 10:58 AM
Garage19's Avatar
Garage19
Due to its material properties the mild steel flange is less prone to expansion and warping than the one constructed from mild steel.
I believe he is implying that he uses the correct grade filler wire to join 316 stainless to mild steel.
Old Dec 17, 2008 | 11:50 AM
Roosie's Avatar
Roosie
my new manifold, im chuffed to say the least
Old Dec 17, 2008 | 11:51 AM
RickyLee53's Avatar
RickyLee53
Yes i'm well aware of this, but the flange doesn't get as hot as the the pipes and the pipes expand also.
The only difference between the 2 is the flange will expand more because it is physically bigger, if this was seen as a problem in his manifold construction then simply adding slots between the cylinders would cure this.
Its an interesting method and i'd assume he'll be using something like a 309L rod to weld the 2 together. But i can't see an advantage other than cost.
Edit, manifold looks cool bolted to the engine with turbo
Old Dec 17, 2008 | 12:27 PM
olek's Avatar
olek
what make is that manifold, Roosie?
what's the inner diameter of the tubes? it looks great, but won't the tubing to the first cylinder come in the way of the pipework for the turbo-outlet?
also, aren't these BR-Racing manifolds the ones made in China with cheap steel and doensn't have purged welds?
Old Dec 17, 2008 | 12:51 PM
RickyLee53's Avatar
RickyLee53
I made that manifold, the inner diameter is 44mm. The cylinder 1 runner is in the best place with the turbo sitting how it does. (length and flow)
If you used a standard cossy turbo then you could send the output pipe between the 2. Or with a bigger turbo just angle it slightly as is pictured.
I'l take a photo of the inside of a manifold here to show the purge.
Old Dec 17, 2008 | 12:57 PM
Garage19's Avatar
Garage19
Ricky,
I can't see the photos of the manifold at the mo.
What wall thickness are they?
Old Dec 17, 2008 | 02:42 PM
RickyLee53's Avatar
RickyLee53
Ricky,
3mm.
Old Dec 17, 2008 | 03:00 PM
Garage19's Avatar
Garage19
Schedule 10 pipe? 1.5 inch nominal bore?
Thats what i've used in the past too. Holds up very well.
Whats your weld procedure / prep? One or two passes? Beveled prep?
Old Dec 18, 2008 | 08:09 AM
Roosie's Avatar
Roosie
I will have to have a custom outlet hose but nothing to worry about
Old Dec 18, 2008 | 09:06 AM
RickyLee53's Avatar
RickyLee53
Yes,
2-3 passes depending when i put in the filler rod. Route/route filler/filler cap.
Prepped pipe.
Old Dec 18, 2008 | 09:23 AM
GaryEvo's Avatar
GaryEvo
roosie will that even fit in engine bay???
Old Dec 18, 2008 | 09:27 AM
Roosie's Avatar
Roosie
yes JUST!!
Old Dec 18, 2008 | 09:28 AM
olek's Avatar
olek
photos are always welcomed
have you tried with diffrent diameters on the tubes? ane experience here?
manifold looks awesome btw, quality work!
Old Dec 18, 2008 | 12:20 PM
RickyLee53's Avatar
RickyLee53
Forgot to take any! Will do later, can't upload till tonight though as phone will only connect to laptop.
I make manifolds in everything from 22mm inner diameter, (1.3 turbo) Upto 50mm diameter, (what it's going on is a secret)
I've back to back tested various designs and sizes. With this been a 500bhp~ car 44mm ID is best IMO. On a standard cossy something a little tighter would give better results IMO.
Sorry for taking over this thread, I'll post a thread when i get chance.
Old Dec 18, 2008 | 03:14 PM
Garage19's Avatar
Garage19
Looks like a nice piece of kit.
Old Dec 18, 2008 | 05:27 PM
Ordered your spacers yet roosie ?
Old Dec 18, 2008 | 10:33 PM
Roosie's Avatar
Roosie
nope still hoping this bloke send them but dont look good at mo
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
xrmalin
Sep 13, 2015 06:52 PM
kevin36
Sep 2, 2015 06:24 PM
