Gun Drilling 2wd cos rear shafts.......
Old Oct 11, 2008 | 11:12 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Default Gun Drilling 2wd cos rear shafts.......
Hi guys,
I fancy having my rear shafts gun drilled, I have a mate who has a precision machine shop and am hoping to get him on the case...
Trouble is I dont know how much to remove, has anyone had this done to their shafts??? If so how much did you take out?? and what power are you running?
Any info gratefully recieved, not just info on cos shafts...any info appreicated
Dan
Old Oct 12, 2008 | 02:10 AM
Rax's Avatar
Rax
whats gun drilled ??
Old Oct 12, 2008 | 02:02 PM
SillyFezzaMk1
Rubber Rhino Crew
basically you drill a a hole throught eh centre of the shafts, effectively creating a tube type shaft which can handle a lot more stress without failure.....also comes with an added benefit of weight saving (not just dead weight but rotational mass which helps reduce Inertia).
Basically I need to know what size hole to drill?? I'll try ringing the specialists monday and see what they recommend.
Dan
Old Oct 13, 2008 | 01:12 PM
SillyFezzaMk1
Rubber Rhino Crew
bumpo
mint_s2
Sep 2, 2015 08:58 AM
atm
Sep 1, 2015 04:56 PM
FlashRS
13
Aug 31, 2015 06:02 PM
rog
Aug 30, 2015 05:32 PM
ray barker
Aug 7, 2015 09:00 AM
