HELP!!! Zetec Turbo oil pressure problem
My mate has a freshly built ZT engine, that sees 1bar oil pressure at tickover (cold) is this normal? I thought it should be higher! Doesnt rise as much as i would have thought when revved either
The crank has had a grind, its got brand new bearings to suit, brand new oil pump, the block and head have been cleaned etc.
It has an oil cooler and remote filter head, -10 fittings and -10 oil return from turbo to sump (T34 turbo)
Any suggestions as to what we should be looking at? really want to get this car to pod on sunday as it should be a bit of an animal.
Thank you please
Steve
Thank you please
Steve
try the gauge, mine had around 60psi i think on cold start up and went down to around 30psi (i think, cant remember now lol). when you say freshly built did he have the crank journals checked and shells to suite? as a damaged crank can cuase you low oil pressure mate, proper tolerences help good oil pressure
Tried a defi guage on it just before we left tonight and it was reading the same, doubt it would be 2 faulty guages, as the defi came off a saff and was reading fine?
Crank tolerances I cant comment on, but its had a grind, and shells to suit, so SHOULD be ok.
And running in and mapping in two days: tall order, I dont know to be honest I was just helping out with it. Whats so "
" about it anyway?
The "
" is the concept of an freshly-built engine with no oil pressure going racing at the pod in two days time.
If the clearances weren't measured when the engine was being built then you're completely blind as to what the possible problem is.
" is the concept of an freshly-built engine with no oil pressure going racing at the pod in two days time.If the clearances weren't measured when the engine was being built then you're completely blind as to what the possible problem is.
Sadly mate,if you manage to map it. i think it'll be dead by the time you do pod
i'd suspect the Crank clearances TBH... mates williams clio had exactly the same
as you are describing, and when he started it up you could hear a funny slight
knock... it was the big ends
got him to turn that off pretty sharpish.. and the 'Tuner' had mapped it on a RR like it
so you ground the crank and he bought the shells steve? ask him what size shells he got as by the sounds of it he's prob put standatd size shells in it. or put a stephascope to the sump/bottom of block and see if you can hear it knocking? i'd near enough put money on it this is whats happened though (well if i had money)
. good luck mate
. good luck mate
. good luck mate
. good luck mateJust had a thought though, AFAIK the company who did the crank didnt have the conrods, so how could they have enough information to get the shells right? Getting confused with it now, and I'm pissed off cos I've left my phone and camera down there
Will have a listen to the bottom end. Its not knocking at the moment, but its looking the most likely cause
No mate, he has had the crank ground, and the same company provided the shells. Thats why it seems weird that the pressure is so low.
thouon the shells. if he has a reciept look what it says was supplied with the crank?
He has aftermarket rods, eagle or arrow, I'm not sure. I was thinking they might have been supplied at (for arguments sake) 100mm, but no-one has checked this, they could be 101mm for all we know
Will check the reciept for the crank too, cheers paul! I'll get you a pint at pod
m8
dump the remote filter setup i had the same problems with my zvh did not matter what oil i used or if the filter was genuine or not, i dont know why this problem exists, i eventually got rid og the remote setup and i have not had a problem since..
sean
Remote oil filter is also something to look at!! very easy to get it the wrong way around.
the oil filter will have a one way valve in it, so will most likely stop most or all of the oil pressure IF the remote system has been plumbed in the wrong way...
As turboboss said above
ditch the cooler and remote set up just for now,
and see what its like then.
What oil temps were you seeing sean?
hi m8
i never had a oil temperture gauge what i used the car for there was no point, the oil would never get too hot for drag or top speed runs, i would most probabaly have one if i done track days....
oil pressure 85psi cold, 50psi warm cruise 25psi idle..
sean
Up again.
Gets 4 bar at idle, but after about 30 sec tickover (still cold) drops to 2 bar?
Anyone think it could be a cracked block or head? I thought we would see mayo oil if it is though?
Or is it too far fetched?
Plastiguage bottom end?
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
