oil breather
Old Oct 7, 2008 | 07:38 PM
dom123's Avatar
dom123
Default oil breather
I need to buy a oil breather for my ecort cos, what is the usall set that you have, mines a small turbo, do i drill the rocker cover? do i need too? what makes are recommended? i'd like a black one really!!
any help would be great
cheers
Old Oct 8, 2008 | 07:43 AM
AlexD's Avatar
AlexD
Post Miester !
I would say buy a Bailey one, I have always used them.
I think GRS do a system that does not breathe into the cam cover.
Just get the alloy tank powder coated black.
Old Oct 8, 2008 | 09:02 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
I would not breath from the top of the cam cover if it was my car. You can use any three-port system, just breath from under the inlet and exhaust manifold and drain to the sump.
I can supply both Bailey and Pro-alloy (who do a black option) products .
Old Oct 8, 2008 | 11:49 AM
Clikettman's Avatar
Clikettman
Do you use a one way valve for the return to the sump ?
I mean, if you don't have a valve, when the pressure enters the sump, the oil doesn't go out via the return hose ?
Old Oct 8, 2008 | 01:36 PM
grcossie's Avatar
grcossie
Have the return under oil level in the sump like the original return, then you dont have any problem
Old Oct 8, 2008 | 01:57 PM
Mike Rainbird
Caraholic
- exactly how it is done .
Old Oct 9, 2008 | 05:16 PM
dom123's Avatar
dom123
sos guys i'm really confused, ive pulled the breather kidney box off and now theres a hole in the block is it one pipe to there, then just below the old kidney box theres a hole in the sump is this another hole that has to breath, or is it the return instead of going to atmoshere and the bolt has to come out under the exhaust manifold for a breath pipe?,
am i right in thinking buy a 3port breather, top left breather pipe to hole under exhaust, top right pipe to old kidney box hole in block, the bottom pipe on the breather goes to the old ford hole in the sump, that use to go to the bottom of the kidney box?
cheers
Old Oct 10, 2008 | 05:37 AM
grcossie's Avatar
grcossie
That`s the way to do it mate
Old Oct 10, 2008 | 06:52 AM
Dave Henshall's Avatar
Dave Henshall
my 'picasso' drawing should explain it all......
Old Oct 13, 2008 | 10:44 AM
j65_xss's Avatar
j65_xss
escort cosworth is nearly
could someone plz give me a good diagram to install a bailey breather system plz and a few pics if possible,
Old Oct 13, 2008 | 10:54 AM
Mike Rainbird
Caraholic
Can you not see the pics above your post?
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
