oil breather
oil breather
I need to buy a oil breather for my ecort cos, what is the usall set that you have, mines a small turbo, do i drill the rocker cover? do i need too? what makes are recommended? i'd like a black one really!!
any help would be great
cheers
cheers
I mean, if you don't have a valve, when the pressure enters the sump, the oil doesn't go out via the return hose ?
Have the return under oil level in the sump like the original return, then you dont have any problem
sos guys i'm really confused, ive pulled the breather kidney box off and now theres a hole in the block is it one pipe to there, then just below the old kidney box theres a hole in the sump is this another hole that has to breath, or is it the return instead of going to atmoshere and the bolt has to come out under the exhaust manifold for a breath pipe?,
am i right in thinking buy a 3port breather, top left breather pipe to hole under exhaust, top right pipe to old kidney box hole in block, the bottom pipe on the breather goes to the old ford hole in the sump, that use to go to the bottom of the kidney box?
cheers
cheers
