Cooling system issue
It never ends, just when i thought i would be going to get an MOT on Monday after the rebuild, i find another issue!!!
Car now runs as sweet as anything after a long time of not running. Car starts first time, no smoke or anything. Car takes a reasonable time to warm up but not too excessive, when the temp gauge gets to just under the 'O' of NORM, the twin Spal fans cut in and believe me, they certainly cool that rad down!! The temp will then settle back to the 'M' of NORM and all seems well..............
BUT the header tank looks like its on the verge of exploding! and the hoses are quite hard! so tried a few things.
1) Heater in car blows out nice warm air which is good
2) Tried taking the pipe off of the top of the Bailey swirl pot and waited for water to come out the top
3) i then allowed the car to warm up, but held the hose that goes back to the expansion tank in the air, and it took forever for any water to come out the top and when it did, it was at boiling point. So fair enough, put it back onto the expansion tank. The thing i noticed was that the water in the tank was also at boiling point, but the return pipe wasnt connected........ that normal?
Either way, im a little concerned!!
all sounds fine they do pressure up a lot thats why some people put the metal header tanks on as turbo's are known for bursting the plastic ones, as long as it doesn't over heat thats ok sounds like your getting a bit to worried over mot
i am, ive just had so many little things, and ive got to the point where i think im being just too fussy over things, yesterday i travelled a 530 mile round trip just for an interior! (the only thing i wanted was doorcards and parcel shelf!)
oh, and the header tank is brand new genuine ford one too, so should be ok!
SMILER258
Sep 28, 2015 09:04 AM
