Escort RS Turbo Series 1 cold start prob
Old Oct 4, 2008 | 08:48 PM
Seriesonersturbowady's Avatar
Smile Escort RS Turbo Series 1 cold start prob
Hi everyone. I have hasd my series 1 now for 4 years with minimul problems,. The other day went out to garage and it wont fire. Tries once and then fails. The only way to get it to fire up is to push down on metering head while cranking and it fires right up. Have checked fuel pressure in the line and it is the 2.7 bar reccomended and stand still and 6 bar when cranking. No fuel pressure problem. Cold start injector not cutting in as its not cold enough. Have replaced the thermo time switch. No better. Have checked for a feed to fuel ecu and it has one. Replaced the KE relay last year so that checks out. Have a good spark and is serviced to the nines. When warmed up i put it on my Co machine and its running at 2.8 % co at 900 rpm at a warm engine temp. Everything checks out apart from i have no voltage to the petentiometer at all. Should i have 8 volts here when the starter is clicked to ensure full fuel delivery on cold start? Does any one know wheather the fuel ecu could be up the spout as i have replaced checked and double checked everything else!! Now concidering a managment change but wanted to keep her original. Any ideas would be appreciated as i have run out of ideas. I have a good idea of how boshe kE works but can not get my head round this one.
Thanks for listening everyone
Jason.
Old Oct 5, 2008 | 05:42 PM
all fixed today. found there was no power to fuel ecu, repaired relay all sorted back to life again.
Old Oct 5, 2008 | 06:20 PM
RScrew69's Avatar
RScrew69
what relay did u repair replace bud?
cheeRS
Old Oct 6, 2008 | 04:36 PM
the ke relay. on a s1 its black and lives under the dash. on a s2 its brown and its in the fuse box. its also fused on a s2 with the heated seats fuse, hope this helps.
Billy_RS
16
Oct 11, 2025 09:41 PM
Archiejay
Aug 12, 2015 12:07 PM
adriansaleem
Aug 1, 2015 09:28 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
Old ford
Jul 31, 2015 06:50 AM
