advice on buying an intercooler. pls help
Old Oct 4, 2008 | 06:37 PM
dom123's Avatar
dom123
Default advice on buying an intercooler. pls help
i want to order my new intercooler tonight for my escort cossie, but just cant decide which make to go for and what size 50mm or 60mm core and the size of the inlet pipe 60mm or the 76mm size.
my cars spec is tt38, 4x4 manifold ported head, seimens 65lb so i want one to make the most of this spec, that could go up 460bhp max
any help would be appreciated , cheers
Old Oct 5, 2008 | 08:41 AM
Golden rule here is the bigger the better generally, just measure the pipe size.
I just fitted airtec rad 60mm and intercooler 70mm, and the rr showed it is excellent at doing it's job, well impressed with them.
Old Oct 5, 2008 | 08:46 AM
dom123's Avatar
dom123
what size inlet & outlet pipes on the intercooler? i cant decide wether to the 60mm or the 76mm as i will need new pipes anyway.
Old Oct 5, 2008 | 04:10 PM
Depends how much power you are going for, but 60 will flow a hell of a lot.
simonmcf
Sep 22, 2015 08:40 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
dojj
Sep 8, 2015 08:31 AM
