is a 1mm overbored 200 block no good for 400bhp
Old Nov 11, 2004 | 04:55 PM
the strut brace's Avatar
the strut brace
Default is a 1mm overbored 200 block no good for 400bhp
thats what i have been told and im confused as fuk , dont know what to do, get a new block or what, anyone know if this is the case???
Old Nov 11, 2004 | 05:01 PM
Ian M's Avatar
Ian M
yes it is why would it not be ????
Old Nov 11, 2004 | 05:09 PM
ImaRacing 700's Avatar
ImaRacing 700
Very dodgy IMO unless you put liners in and run std or .25 pistons!!!
Old Nov 11, 2004 | 05:28 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
Default Re: is a 1mm overbored 200 block no good for 400bhp
1mm oversize is not a good idea due to the amount of metal removed from the bore this creates to much heat into the block which can cause cracking into the water jackets
if your car is 2WD just rebore your old block .25 why waste money on something you dont need
Old Nov 11, 2004 | 05:30 PM
the strut brace
they reckon, its a lot more liable to twist?, okay for 330ish but no good for above that, thats what i was told?
Old Nov 11, 2004 | 05:33 PM
ImaRacing 700
The 205 std block has a flex rating of 380bhp and in a 2wd its fine as at 400bhp you WILL be wheelspinning which takes the flex away!
Old Nov 11, 2004 | 05:34 PM
the strut brace
pete, i have got at the minute a 200 block in my car thats been oversized to .5mm, the twat dropped the rod so i need to rebore it to 1mm as it has slight scoring, prob is its a waste of money buyin 1mm oversized pistons to do it if at the end of the day 1mm wont be any use for 400bhp, might as well get a replacement block which i can buy std or.25 pistons for and then it will be ok , thats my theory anyway
Old Nov 11, 2004 | 05:35 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
i had a 400bhp 1mm oversize e nngine and it worked fine
Old Nov 11, 2004 | 05:38 PM
Dirty Harry
Super Moderator
ask yourself this simple question
what did the big power boy use before the 200 block came out??nothing wrong with the good old 205 block in a 2WD high power motor I have seen more 200 blocks crack than 205,I had a call from a repitable rally cross engine builder once needing a block it had to be the very first 200 block as the rest according to him are crap
Old Nov 11, 2004 | 05:39 PM
the strut brace
i aint got a 205 block though pete, its a 200
Old Nov 11, 2004 | 05:42 PM
Dirty Harry
Super Moderator
rebore it then to .25 Ł400 for pistons job done
Old Nov 11, 2004 | 05:44 PM
the strut brace
put ya glasses on pete its already overbored to .5 and needs to go to a 1mm which supposedly is shit
Old Nov 11, 2004 | 05:45 PM
Dirty Harry
Super Moderator
Ohhh I should learn to read put it on E bay and get a 205 block
Old Nov 11, 2004 | 06:10 PM
Mr RS500's Avatar
Mr RS500
Call me , i have a super dooper 200 block fully rebuilt motor , not even run yet
Old Nov 11, 2004 | 06:13 PM
Danny B's Avatar
Danny B
I agree that 205 block is just as good, dont limit yourself and if your buying a block concider a good 205 block and have minimal bore
Old Nov 11, 2004 | 06:18 PM
Rs Gus's Avatar
Rs Gus
i know someone wo uses a 205block 2.25mm oversize at 30 psi
Old Nov 11, 2004 | 06:21 PM
peteh's Avatar
peteh
put's my mind at rest abit, my 205 block is 1mm oversized and i only wana run low 20's
Old Nov 12, 2004 | 06:56 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i'd check the meaning of the before getting too excited.
i'd guess a 2.25mm overbore is to fit liners?
personally i would not want to go more than a 0.5mm overbore on any cossie engine. there's no need when there's so many 205 blocks out there.
Old Nov 12, 2004 | 07:54 AM
AlexF's Avatar
AlexF
Jesus what a load of shite
Old Nov 12, 2004 | 08:11 AM
Dirty Harry
Super Moderator
[quote="J871yhk"]
Jesus what a load of shite [/quot
would you mind telling all why ???????
Old Nov 12, 2004 | 08:27 AM
Disabled Account's Avatar
Disabled Account
???? Sorry to pick holes, but please explian Phil............
Old Nov 12, 2004 | 11:09 AM
Ian M's Avatar
Ian M
so do i
Old Nov 12, 2004 | 11:10 AM
Ian M's Avatar
Ian M
well you would be wrong then
Old Nov 12, 2004 | 12:35 PM
AlexF's Avatar
AlexF
Bore flex is not related to wheel spin!
alex
Old Nov 12, 2004 | 12:40 PM
ImaRacing 700
Alex....a 4x4 will GRIP thus cause MORE flex in the block...a RWD just spins thus decreasing FLEX...are you a pro????
Old Nov 12, 2004 | 12:43 PM
JRST's Avatar
JRST
phil. y is it only rated at 380bhp?
Old Nov 12, 2004 | 12:50 PM
JRST's Avatar
JRST
phil? you there mate.
ok. can anyone answer that question for me please.
stu, karl, mike, madevelopments etc
please
Old Nov 12, 2004 | 12:52 PM
ImaRacing 700
A std 205 block is 380bhp rated a 200 block is 500bhp rated the RS500 is 800bhp rated...all FLEX rated.
Basically if you are running 4X4 you NEED a 200 block as the grip increases the twist...on a 2wd a 205 is safe to any bhp as over 400 you aint gonna grip LOL unless you obviously spend a lot of cash modifying the back end and in that case you are loaded...ROFL.
Old Nov 12, 2004 | 12:54 PM
ImaRacing 700
Have a look at a 205 block compared to a 200 or rs500,look in where the water pump is you can see lots of xtra meat...Just a lot more metal for strength....You will find most over 600bhp YB blocked cars if done properly are linered making flex rating stronger as the bore walls are stronger.
Old Nov 12, 2004 | 12:59 PM
JRST's Avatar
JRST
thank you phil
Old Nov 12, 2004 | 01:03 PM
Matt's Avatar
Matt
not on here you wont how many are there on here and how many are linered blocks i suppose these are all "not proper" you and your fucking pringle tube blocks
Old Nov 12, 2004 | 01:08 PM
ImaRacing 700
Matt you are very nieve if you think over 600bhp motors aint linered probably only Karls if he took that at full power on a track day it wouldnt last long imo...i can tell you this ALL my engines are linered and the metal is stronger than the original block...i WONT crack my block in the bores FACT.
nikasil linered...is just a better grade of material than mine...but then i dont run 600 plus bhp!....also your looking at 3 times the cost.
Old Nov 12, 2004 | 01:10 PM
JRST's Avatar
JRST
so matt, do you agree with what phil is saying about the 205 block?
is this 380 bhp rating correct.
markk
Dec 2, 2021 06:59 PM
James Porter
Oct 28, 2015 12:17 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Zoggon
Aug 10, 2015 10:39 AM
