Front Shock ABS Wire Clips - Solution Found !!
Old Oct 1, 2008 | 09:21 PM
AlexD's Avatar
AlexD
Post Miester !
Default Front Shock ABS Wire Clips - Solution Found !!
I am after a couple of the black clips that attach to the metal bracket that goes round the front shock.
Ford reckon they dont stock them anymore.
Ta..
Old Oct 2, 2008 | 07:19 AM
Franco's Avatar
Franco
Cable tie no good then?
Old Oct 2, 2008 | 07:42 AM
AlexD's Avatar
AlexD
Post Miester !
i was trying to do it properly for once ..lol.
Old Oct 2, 2008 | 08:10 AM
Franco's Avatar
Franco
Well that's bloody Ford for you Alex!
Old Oct 2, 2008 | 08:12 AM
AlexD's Avatar
AlexD
Post Miester !
thats the bracket i mean just above the hub.
Old Oct 2, 2008 | 08:29 AM
Franco's Avatar
Franco
can you not take off, clean up and reuse?
Old Oct 2, 2008 | 08:57 AM
AlexD's Avatar
AlexD
Post Miester !
Yes the metal brackets i am , its the small black plastic abs wire holder
that attaches to it to hold the ABS Cable i need .
Old Oct 2, 2008 | 09:13 AM
The Youth.'s Avatar
The Youth.
find a granada mk3 or xr4x4 sierra in a scrappy and use them, thats what I did when the metal parts of mine fell apart, ford don't have any of the metal parts left either.
steve
Old Oct 2, 2008 | 09:18 AM
Franco's Avatar
Franco
Yes mate, thats what I'm taking about. Give it a clean and a coat or two of 303 Aerospace: http://www.cleanyourcar.co.uk/interi.../prod_366.html
Old Oct 2, 2008 | 12:00 PM
dan le moignan's Avatar
dan le moignan
Bummer if they are NLS as i require one also!
Old Nov 9, 2008 | 12:06 PM
AlexD's Avatar
AlexD
Post Miester !
I have found a solution for the ABS Wire Bracket/Clips !
The old ones have the plastic clip,the new ones do not.
However they do the same job, are still available and hold the abs wire perfectly.
I was lucky i found the old plastic clip attached to the cable
i did not notice it has slipped down to the calliper .
Still glad i found a replacement now if i need them .
Old Nov 9, 2008 | 02:23 PM
dan le moignan
Alex is that the part no on the bag? 6158579?. i need a replacement as one of myne snapped!
Old Nov 9, 2008 | 03:00 PM
THE RADMAN's Avatar
THE RADMAN
good info there they do rot very easily,what car are they from?
Old Nov 9, 2008 | 05:55 PM
AlexD's Avatar
AlexD
Post Miester !
We found them on the clips / abs connectors various page on microcat.
I will double check the code tomorrow.
Old Nov 10, 2008 | 12:34 AM
cosmo V6's Avatar
cosmo V6
GOOD FIND
Old Nov 10, 2008 | 10:15 AM
AlexD's Avatar
AlexD
Post Miester !
Correct .
original
Apr 28, 2026 05:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
