help needed from an electrician please
Old Oct 1, 2008 | 04:45 PM
banhambuilt's Avatar
banhambuilt
Default help needed from an electrician please
background first
the house i got now has bugger all plug sockets in each room,mostly 2 singles.
the electrical box has the old fuse wire inserted on the fuses
the house is a concrete fabricated one with brick outer finish.
my question is
i want to install shed loads of double sockets in the various rooms.
i remember a while ago screwfix had a box type thing that you installed on a rota stop sds drill and it basically chisselled the wall to the correct size.
i have looked everywhere to find it,chiselling it sounds like shed loads of work when i can get a tool to do it.
anyone got or know where i can get one from?
i will be getting a qualified electrican in to update my consumer box and re-wire the house,unless someone local to north staffs fancies a cash job?
cheers
lads
Old Oct 1, 2008 | 05:03 PM
focusv8's Avatar
focusv8
http://www.screwfix.com/prods/91913/...-Sinker-Double
Plus;
http://www.screwfix.com/search.do;js...=76313&x=9&y=4
If your walls are "No-fines" concrete I think you'll be wasting your money with the above.
Old Oct 1, 2008 | 05:09 PM
mark r's Avatar
mark r
your proberly better of hiring an angle grinder and chasing the walls out.will be messy job but the quickest way if walls are solid concrete
JoeyBoyden
Jan 4, 2024 02:36 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
