engine problem
Old Sep 29, 2008 | 10:11 PM
Korda's Avatar
Korda
Default engine problem
iv just picked up a s2 turbo runs fine when on motor way, but cuts out in traffic or lights, will start but only for 3 secs, its had new arm, diz, leads,
Old Sep 30, 2008 | 06:42 AM
If you are saying it doesn't idle just turn up the idle speed a bit first.
Old Sep 30, 2008 | 07:52 AM
Korda's Avatar
Korda
i had the aa out and where as helpfull as my wife. is the diz easy to set up. its new so i think the timeings out
Old Sep 30, 2008 | 08:02 AM
Yes just a timing light needed that's all.
Old Sep 30, 2008 | 01:41 PM
JonathanJ's Avatar
JonathanJ
If it is running std then ussually there are a punch mark on head and dizzy body that is set at factory as a ball park setting
Old Sep 30, 2008 | 03:03 PM
Korda's Avatar
Korda
thanks for all your help shes up and running timeing was well out and fuel.
Old Oct 1, 2008 | 02:16 PM
Korda's Avatar
Korda
after paying out money to get set up now it wont start again been told the meter reading units gone, iv got a new top part of the unit just need the bottom part any one with one
Old Oct 1, 2008 | 07:52 PM
mark2's Avatar
mark2
i have the hole metering unit pm me
Old Oct 6, 2008 | 02:36 PM
Korda's Avatar
Korda
hi mark got a meter unit today just fitted it started the car and still runs the same as the last meter unit the the box of matches and petrol is looking good help
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
da52rkn
Ford Focus Range
Aug 21, 2015 04:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
Blown Hell
Aug 5, 2015 07:22 AM
