installing a volt meter
Old Sep 29, 2008 | 06:16 PM
Trotter's Avatar
Trotter
Default installing a volt meter
best place to wire it up pleaseas it has no instructions,straight off the battery +?
ammeter went back on the advice here,many thanks for that
Old Sep 29, 2008 | 07:02 PM
jock05's Avatar
jock05
Wiring in direct to the battery will give you a reading all the time. You need to connect it so that it reads when the ignition is on. For example tapping into the headunit supply (assuming the unit switches off when you turn the car off).
Old Sep 29, 2008 | 08:15 PM
Trotter's Avatar
Trotter
ok so any + that is live when ignition on
thanks mate
DixieTheKid
11
Jun 6, 2020 11:20 AM
Nov 1, 2015 06:53 PM
gingeRS
17
Oct 2, 2015 09:42 AM
