crankshaft thrust washers?
Old Sep 28, 2008 | 04:11 PM
105epwr's Avatar
105epwr
Default crankshaft thrust washers?
ive had my crankshaft ground on my cossie to .25 can you use the std thrust washers still?
Old Sep 30, 2008 | 07:01 AM
JonathanJ's Avatar
JonathanJ
I would alway carry out an end float check during build , just to make sure that they are the correct size , have known oversize thrusts to be fitted to a new engine , fit crank and use dti to make sure end float is within spec
Old Sep 30, 2008 | 08:05 AM
The thrust part of the crank is not ground, but may be worn.
Always measure, if in doubt get new std size ones, as the tend to come slightly thicker than needed and you can then grind them down on a glass with grinding paste.
jessie_rs
62
Aug 6, 2019 09:27 PM
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 24, 2015 11:11 AM
DavidK
Sep 27, 2015 02:55 PM
Kam B
Sep 24, 2015 10:40 AM
