Quest about Diff and Diff oil
Old Nov 10, 2004 | 09:22 PM
Rhys's Avatar
Rhys
Default Quest about Diff and Diff oil
When me car is up in High MPH i got a film of diff oil over the back of my car. Suppose this could be cos i have over filled it maybe? If so what the best way to get it at the right level of oil when its on the car, and if its not over filled where would it leak from?
Old Nov 10, 2004 | 09:35 PM
3drstretch's Avatar
3drstretch
If the diff is at the wrong level.Just undo the filling nut and wait.When no more comes out it is right.Make sure car is on flat road.As the level is the bolt hole.
You sure it diff oil
Old Nov 10, 2004 | 09:36 PM
Rhys's Avatar
Rhys
Yeah deffo diff oil as u can smell it, Though how can i undo the nut on a level surface when i got to jack the car up to get to it? doh
maybe try and get under there tomorrow now its higher
Old Nov 10, 2004 | 09:39 PM
3drstretch's Avatar
3drstretch
Either Jack the front up the same as rear or find a friendly garage who will borrow you a ramp for 5 mins.
Old Nov 10, 2004 | 09:41 PM
CosKev3's Avatar
CosKev3
Need to do it over a pit or drive on/4 poster ramp if u want it really flat
Should be easy to spot if its leaking from diff once you get under there
Old Nov 10, 2004 | 09:44 PM
Rhys's Avatar
Rhys
Job to do on Friday i think no where can i find a nice ramp
Old Nov 10, 2004 | 09:45 PM
CosKev3's Avatar
CosKev3
Could be gearbox oil?
Did you take complete engine/box out when you had rebuild or split engine off box
in car?????
Old Nov 10, 2004 | 09:47 PM
Rhys's Avatar
Rhys
Nah split engine and box mate, im sure its the diff as it smells like it, and i got a bit of oil on the floor at rear of garge. Hmm best get it checked as wouldnt want that to run out of oil
Old Nov 10, 2004 | 09:54 PM
CosKev3's Avatar
CosKev3
Ahhh,if you've got puddle at rear must be diff
4 places it could leak,input seal on front,driveshaft seals(1 either side),
or rear cover(very unlikely)
Unless when the car was so low you've worn/cracked the bottom of diff casing.................looking on the bright side
Old Nov 10, 2004 | 09:59 PM
Rhys's Avatar
Rhys
dont joke mate i have grouns some of my case on the diff at the back
But to be honest it looks like its coming from further up after quick look. Will clean it off and go from there i suppose
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
Fudgey
21
Sep 30, 2015 06:19 PM
