cosworth oil return
Old Sep 26, 2008 | 07:33 PM
proboscus's Avatar
proboscus
Default cosworth oil return
when using a bailey oil separator can the original oil return port be used for this purpose(just behind where the original kidney box sat) or do i have to use the bung on the exhaust side of the block?
Old Sep 27, 2008 | 12:23 AM
LHD220Turbo's Avatar
LHD220Turbo
no need to post it 3 times bud! - you'll get a response but not straight away!
https://passionford.com/forum/general-car-related-discussion/260881-cosworth-oil-separator.html
Old Sep 28, 2008 | 05:18 PM
105epwr's Avatar
105epwr
mine was all plumbed in wrong so now-
exhaust side port on the block goes to top of seperator port
kidney bowl side goes to other side of seperator port(other top port)
the large bore port on the seperator(bottom of it)goes to atmosphere under car
then the small port on the bottom of seperator needs to be used as a drain off to sump.
hope this helps?
Oct 9, 2015 07:38 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Adam-M
Aug 26, 2015 05:53 PM
Aug 14, 2015 07:29 AM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
