amal valve
Old Sep 25, 2008 | 11:15 PM
mark2's Avatar
mark2
Default amal valve
hi
if an amal valve on a series 2 was faulty could it cause the car to lose boost
the amal clicks on the turn of the key and when disconnected boost stays at 7 psi
but when connected boost rises to 12 psi then falls to 7 psi the car is set to run 12 psi
hope someone can help
mark2
Old Sep 26, 2008 | 05:51 AM
Unlikley to be the valve as it sounds as though it is working, it only follows instructions from ecu.
Old Sep 26, 2008 | 09:34 AM
mark2's Avatar
mark2
so is it possible that the pulse from ecu is braking down and sending wrong pulses to amal which could in turn make the boost drop
i did remove the amal and tried an adjustable boost valve and got stable/holding boost from 7psi fully closed on valve and driving lovely .
upto 9psi with only a 1 1/4 turn on the manual controller but to laggy for me but holds boost
so am i right in saying with the amal connected the actuator rod is say set to 6/7 psi and the bleed off from amal makes it rise to the 12psi but as there is somethink wrong there is boost drop
so if i remove amal valve and have bleed valve in its place fully closed and 7psi and say take the boost up by the ac/rod to say 11 psi am i right it still will be laggy even thou bleed valve closed at the moment as i only found it laggy when adjusting the bleed valve
mark
Old Sep 26, 2008 | 12:14 PM
mark2's Avatar
mark2
cracked it i now have stable boost
removed amal valve and now have constant pull with no spiking ok i used a 3 port bleed valve untill i get an electronic boost controller
can anyone recommend one that works well on erst mfi
cheers
mark2
steve.rst
Mar 15, 2016 08:01 AM
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
rs_jim
Sep 19, 2015 08:41 PM
