2.2 tdci in a mk1 focus. Possible?
Sep 25, 2008 | 09:45 PM
230km/h+ in an oil burner
will it fit?
i'm thinking dumping my 1.8tdci engine for an s-max 2.2tdci. is it possible to do?
Sep 25, 2008 | 09:50 PM
Ford did a press release and stated it would not fit. This was in the Mk2, so I don't think it would. If it did, you would be as quick as a focus RS remapped.
Benni.
Sep 25, 2008 | 10:10 PM
Any engine will fit in a Focus, how much time and money do you have?
Can't see a 2.2 being very hard to fit in.
Sep 25, 2008 | 10:40 PM
i know that the 2.0tdci fits causa i've seen it done.
is the 2.2 much much bigger?
focusv8, i don't have a fixed budget. i already have an S-max for donnor.
benni, it would be even quicker
Sep 26, 2008 | 01:09 AM
Quote:
Originally Posted by
Crazyass
Very nice, what would be your plans?
Benni.
Sep 26, 2008 | 05:24 AM
Resident Wrestling Legend
unbolt the subframe from the smax and bolt it into the focus
Sep 26, 2008 | 07:25 AM
dojj
Thats your answer for everything
Sep 26, 2008 | 07:58 AM
If a 2.0 will fit then a 2,2 will!!
BOth engines are from the Puma family (sold as Duratorq) and the 2.2 is a 2litre bore with a 2,4 crank.
Alex
Sep 26, 2008 | 04:37 PM
Gary_ST
they are all the same mate
so you remove it from the donor, and put it into the reciver
then put some electricity through the wires, some petrol (or in this case, deisel) into the pipes and fire her up
Sep 27, 2008 | 10:09 PM
Benni
Benni.
probably something in the lines of a 2.2 engine with a big pro alloy ic for the focus RS, a big vnt25 turbo, bigger exhaust, cams, custom manifold, remapped... the works... something a little bit faster than it is now
Sep 27, 2008 | 10:13 PM
dojj
doesn't look quite as simple as that
Sep 28, 2008 | 09:01 PM
2.2 from the smax?
they don't do s 2.2 smax?
Sep 28, 2008 | 10:32 PM
James
2.2 from the smax?
yeah, the 2.2 diesel engine.
you're probably thinking in the 2.5t engine shared with the focus ST
Sep 28, 2008 | 11:56 PM
dojj
Surely it's not that simple? What you have planned sounds great, be sure to start a project thread.
Benni.
Sep 29, 2008 | 07:09 AM
fairlys ure everything is the same on the cradle side of things mate
just had a look under a few of the connects and they share the same sort of locationg points as the mondeo for the cradle
even the hubs are the same i know this for sure as i've seen a few of them apart
so it really is as simple as finding a donor car, complete
unbolting the 4 big bolts for the subframe
wheeling it out from underneath and bolting it into the car you want to use
plus fuel and sparks and away you go
Sep 29, 2008 | 08:37 PM
AlexF
Alex
thats whats confused me!
the 2.2 in the smax is a dw [psa] engine, same as the 2.0 tdci in the mk2 focus/cmax/mondeo/kuga/galaxy.
swapping subframes? no-way will a smax/galaxy subframe simply bolt in to a focus!
Sep 30, 2008 | 06:15 AM
they bolted a focus rs subframe into a transit connect
there's a thread on it just this morning
the cradle locating points may differ, but that's going to be about it, everything else should just swap over nice and easy, he'd just need to sort out the engine mount locations and job jobbed
Sep 30, 2008 | 05:30 PM
thing is a transit connect is based around a focus chassis!
Oct 3, 2008 | 02:07 PM
As James says above, the Transit Connect is just a Focus van.
Oct 3, 2008 | 03:50 PM
i have looked under my full sized tansit today and it looksl ike it's got very similar mounting points to the mondeo
Feb 6, 2013 | 08:08 AM
After you bolt the engine in, you will meet a ugly bitch, called CANBUS!
Aint gonna work M8. Unless you have unlimited time and money!
Feb 6, 2013 | 08:24 AM
Feb 6, 2013 | 09:43 PM
275o
dont know about the money but time shouldn't be a prob
since this thread was started nearly 5 years ago
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
18 ,
20 ,
22 ,
engine ,
fit ,
focus ,
ford ,
manifold ,
mk1 ,
rs ,
swap ,
tdci ,
turbo ,
vnt25 ,
weight
