2.2 tdci in a mk1 focus. Possible?
Ban[B][/B]ned
Ford did a press release and stated it would not fit. This was in the Mk2, so I don't think it would. If it did, you would be as quick as a focus RS remapped.
Benni.
Benni.
230km/h+ in an oil burner
i know that the 2.0tdci fits causa i've seen it done.
is the 2.2 much much bigger?
focusv8, i don't have a fixed budget. i already have an S-max for donnor.
benni, it would be even quicker
Ban[B][/B]ned
Ban[B][/B]ned
Resident Wrestling Legend
fairlys ure everything is the same on the cradle side of things mate
just had a look under a few of the connects and they share the same sort of locationg points as the mondeo for the cradle
even the hubs are the same i know this for sure as i've seen a few of them apart
so it really is as simple as finding a donor car, complete
unbolting the 4 big bolts for the subframe
wheeling it out from underneath and bolting it into the car you want to use
plus fuel and sparks and away you go
the 2.2 in the smax is a dw [psa] engine, same as the 2.0 tdci in the mk2 focus/cmax/mondeo/kuga/galaxy.
swapping subframes? no-way will a smax/galaxy subframe simply bolt in to a focus!
they bolted a focus rs subframe into a transit connect
there's a thread on it just this morning
the cradle locating points may differ, but that's going to be about it, everything else should just swap over nice and easy, he'd just need to sort out the engine mount locations and job jobbed
