Ford rebuild lock kit
Old Sep 25, 2008 | 06:41 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Default Ford rebuild lock kit
anybody done one? any step by step guides about as tere are loads of little bits in the kit
Old Sep 25, 2008 | 06:49 PM
rocky_robin's Avatar
rocky_robin
I'd love to know too as I've got about 4 sets & I want new locks on my van! I've tried searching on the net but got no where.
Old Sep 25, 2008 | 07:01 PM
fordrallycar's Avatar
fordrallycar
Your ford dealer should do it for you or they will explain what to do
Old Sep 25, 2008 | 07:03 PM
©hatter Box's Avatar
©hatter Box
pice of cake after you done it a few times it so easy you just need to know how to read a ford key there will be no where on the net that tells you
Old Sep 25, 2008 | 07:07 PM
fraser9764's Avatar
fraser9764
you can find anything on the net if you look hard enough...
when i bought my van i asked for the drivers door lock to be changed as someone had had a go at it in the past, when i called in to see when it would be ready the bloke was fiddling with it, looked far too complicated
btw that was just some random garage, not ford.
Old Sep 25, 2008 | 07:08 PM
col cos1's Avatar
col cos1
my local ford garage done it on the side for a tenner on a mechanics lunch break
Old Sep 25, 2008 | 07:11 PM
mercury grey minter's Avatar
mercury grey minter
Have you got the old barrel complete?
Iv,e done loads of ford lock sets.Can be quite fiddly.
Post me the bits and i'll rebuild it for free if you want
Old Sep 25, 2008 | 07:24 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you get the barrel
you pop the circlip off the end
the lock comes out
it won't fall apart as it's got so much grease in it
look at it to see how it goes together
don't loose the locking pin
don't jumble up the numbers of the tabs
don't forget how to put the washers back together again
other than that, it's easy
Old Sep 25, 2008 | 07:34 PM
Paulo P's Avatar
Paulo P
Matt if you'd like my brother to do it for you let me know because I'm in Farnborough on Saturday. My Brother works for Ford in parts and builds locks
Paul
Old Sep 25, 2008 | 07:37 PM
denbo's Avatar
denbo
Easy when you have been a locksmith and when you know how to read the key aswell
Old Sep 25, 2008 | 07:44 PM
Matt Baxter
Back in black!
Paul
I would be well up for that but i am working all fucking day cheers anyway Paul
Old Sep 25, 2008 | 07:46 PM
Matt Baxter
Back in black!
dont have the old barrel
Old Sep 25, 2008 | 07:58 PM
Paulo P's Avatar
Paulo P
What time are you at work until? I'm there by the 6th form college until the evening
Old Sep 25, 2008 | 08:25 PM
Matt Baxter
Back in black!
working till about 5.30pm
gunna have a go in a bit will see how i get on
Old Sep 25, 2008 | 09:29 PM
Matt Baxter
Back in black!
Done it
Just got to get an e clip for the bottom
Cheers for the offer Paul
Old Sep 25, 2008 | 09:51 PM
Paulo P's Avatar
Paulo P
Nice one The clip is available from Ford too
Old Sep 25, 2008 | 09:57 PM
Matt Baxter
Back in black!
yeah yet another trip to the parts dept tomorrow
I would of thought that it should of came in the kit
Old Sep 26, 2008 | 09:12 AM
rocky_robin
If I went into my local Ford dealer and asked them to rebuild it, they'd probably say that the part was obsolete on their system so would refuse to talk any further nor give any advice
I've got locks c/w new keys too. I'll have sit down one night and have a look......... thanks all.
Old Nov 10, 2008 | 05:36 PM
Graham S1's Avatar
Graham S1
OK, can anyone help me out with this?
I have taken apart my petrol cap lock. The only trouble is, the wafers with the numbers stamped on, don't match the key number.
Numbers on keys.
222413 (Not actually in that order)
And the numbers on the wafers....
3x "D", 1 x "2", and 1x "3", and one blank (that looks like a "D")
I've nearly got it to work. I can twist the petrol cap from the back to lock it, but can't do it from the other side with the key. Doing my nut in.
I thought the "D"s might be "2"s, but then I've got a wafer with "2" stamped on it. "D" can't be "1", as there are 3(4?) of them, and only one occurence of the number "1".
Is there some sort of secret code?
Old Nov 10, 2008 | 11:03 PM
dojj's Avatar
dojj
thats the wrong key then mate
Old Nov 11, 2008 | 07:00 PM
Graham S1's Avatar
Graham S1
Well, I'm trying to make a petrol cap lock, from a boot lock, and it's from a new set, so it should match up.
Old Nov 11, 2008 | 08:45 PM
dojj's Avatar
dojj
your key has 3 different numbers on it
the lock has 4 different numbers in it
i would hazzard a guess at the d being a zero?
Old Nov 11, 2008 | 11:00 PM
cozzfather's Avatar
cozzfather
C.R.E.A.M.
i have done it by goin the car breakers yard and pulled a few random locks out of passenger doors that havn't had much wear and stripped them and then made sure i have pulled the numbers out carefully of the one that needs rebuilding and boshed it all back together, its tricky until you do it a few times infact i have done it and then a few years later struggled until i remembered how to do it
steerfromdarear
28
Jan 29, 2016 06:14 PM
borboyous
Aug 22, 2015 11:17 AM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
