what suspension on escos??
Old Sep 25, 2008 | 03:13 PM
vokal's Avatar
vokal
Default what suspension on escos??
koni adjustables with either spax springs or cobra sport springs?
or
avo coilvers?
opinions and or users of?
cheers guys
Old Sep 25, 2008 | 03:14 PM
Kelv's Avatar
Kelv
Almost there!
Koni adjustables with Ahmed spec springs would be my vote mate.
Old Sep 25, 2008 | 03:16 PM
vokal's Avatar
vokal
they're the leda ones from r&b innit?
how much they lower it by?
Old Sep 25, 2008 | 03:47 PM
Kelv's Avatar
Kelv
Almost there!
innit?
yes mate, they are available via Mike Ranbird (R & B)
pound for pound, they will be alot better road quality with superb road handling characteristics compared to a set of Gaz/Avo coilovers.
Old Sep 26, 2008 | 08:17 AM
vokal's Avatar
vokal
isn't it, lol cheers for your help kelv
do you know how much they will lower it by?
Old Sep 26, 2008 | 09:00 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
10-15mm.
Old Sep 26, 2008 | 09:13 AM
Ahmed springs are very good, had these(borrowed) for a few weeks while avo coilovers were away for rebuild.
I would say it depends on what you want to do with the car, and suspension is a very personal thing, why not take your time and try to blag rides in cars with different set ups, would be my advice if you can.
Myself I found the ahmed very good but way too soft for me, had spax before as well as chassis dynamics(avo) std ride height and lowered on 3 door and cos std ride height chassis dynamics are excellent and I prefer these over ahmed.
My fave though is AVO, I like the ease of adjustability with coilovers(height wise) and avo seem my sort of damper.
I would seriously look at KONI adjustables with either ahmed or chassis dynamic springs for the road, just run koni on hardest setting, nice and comfy.
Old Sep 26, 2008 | 10:05 AM
vokal's Avatar
vokal
i'll be mainly using it for fast road use but next year i'd like to use it on the track.
i have avo coilovers on my mk2 golf gti and they're ok but obv an escos is a bit of a different animal and would prefer it a little more civilised not quite so jaw chattering lol
mike r - i'd prefer to lower it more than that i know the arguments against for suspension geometry and stress on the 4x4
any one in the bristol area with various set ups?? not drivin the car atm so aint popped upto the bristol rsoc meets
Old Sep 26, 2008 | 10:21 AM
J1mbo's Avatar
J1mbo
B1mbo
Old Sep 26, 2008 | 10:33 AM
vokal's Avatar
vokal
still guna ride a bit high for my liking ideally i'd like to lower it 25-30mm so what are the best springs avaiable to lower it this much?
thanks for the input so far appreciated!
Old Sep 26, 2008 | 10:57 AM
Mike Rainbird
Caraholic
It will handle WORSE with the car lowered to that extent, it's got nothing to do with the geomtery (on the front), it is the roll centre, which is basically placed below ground level if you lower an Escort/Sapphire this much. If you want to go on track, then you're wasting your time lowering it by the extent you suggest "looks good".
Obviously the rear tyres will also wear at an excessive rate (due to the camber) and you will have huge problems with bump steer on the rear, along with reduced levels of grip (especially in the wet, as the rear tyres will be just running on the inner edges).
Old Sep 26, 2008 | 11:36 AM
vokal's Avatar
vokal
is there anyway to adjust the camber on the rear? sure you've go shims on your site? obv need adjustable track control arms on the front. got laser wheel alignment at work so i can set it all up on that after lowering it.
what if i put different wheels on will that affect the roll point of the car?
Old Sep 26, 2008 | 11:40 AM
Mike Rainbird
Caraholic
An adjustable beam.
The shims I do are for the toe only.
Different size wheels / tyres* (*which must have the same rolling radius) will affect the ride height, but then it depends on how much the car is lowered.
Look in the Escort section of this Forum, and you will see some pictures of cars fitted with Ahmed springs .
Old Sep 26, 2008 | 12:02 PM
vokal's Avatar
vokal
4t that might be the only way lol
if i went 225/35/18 there would be hardly any diffence in tyres diameter to 225/45/16 std wheels&tyres only 6mm or something like that
got a link to a car with ahmed springs? dont you do them in 2 different stiffnesses?
Old Sep 26, 2008 | 01:11 PM
booner999's Avatar
booner999
i have a standard cosworth setup on my escossy, good enough for me
Old Sep 26, 2008 | 01:24 PM
vokal's Avatar
vokal
i agree but why not make it better?!!
Old Sep 26, 2008 | 05:33 PM
booner999's Avatar
booner999
for the price of a good suspension setup is prob a grand, and then its doing it, for the bit extra you gain from using it on the road, its just not worth it. Can you really push one to its limits on standard springs legaly?
Old Sep 26, 2008 | 05:39 PM
ECOS95's Avatar
ECOS95
The standard stuff on the newest Escort is getting on for 12yrs old now, ok in some cases the car might not of done many miles but the setup was a compromise from the factory. If you start using the power you'll soon find the standard suspension lacking & thats before you get to the brakes. Just my opinon.
& you'll be looking at more than a grand for a good road setup, you can spend that on just the Adj rear beam (before fitting)
Old Sep 26, 2008 | 05:43 PM
vokal's Avatar
vokal
dont cost me anyting apart from parts i'd jus fit it all myself at work or at home an set all the geomtry up at work so its jus a time thing really.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
SMILER258
Sep 28, 2015 09:04 AM
