Ofac or Ofab on frst
Old Sep 25, 2008 | 01:48 PM
FRST_87's Avatar
FRST_87
Default Ofac or Ofab on frst
How can i find out if i'm running ofab or ofac on my frst?
Grtz
Old Sep 25, 2008 | 01:56 PM
Stu @ M Developments's Avatar
PassionFords Creator
Grtz
Its printed on the ECU label.
Alternatively, if the map sensor is made by weber it is SUPPOSED to be an OFAB. But still may not be.
Old Sep 25, 2008 | 02:06 PM
FRST_87's Avatar
FRST_87
The ecu is located behind the dash? the map sensor has a ford stamp and the following numbers:
- E7EF-9F479-A2A
- OL21A
Old Sep 27, 2008 | 11:47 AM
FRST_87's Avatar
FRST_87
up
Old Sep 30, 2008 | 11:00 AM
NATH-RSZT's Avatar
NATH-RSZT
can you see the map sensor clearly i.e face on ifso then its ofac. if the map sensor is facing downwards on a bracket then its ofab.
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
Dahl88
Aug 22, 2015 08:16 PM
