Opinions on Gotech mfi - features etc
Just want to get a unbiased opinion of the gotech mfi ecu and the features it provides. Any comments appreciated.
A few people on the sx owners club reckon it was a backwards step from my standard ecu so much so they pm'd me!
Is it on a par with a standard L8 or any of the other brands. I swapped from coilpacks to conventional coil and plugs which was also pointed out was a step backwards is this the case?
Here's the link to the gotec site and mine is the standard mfi. There is also software demonstrations on the site.
http://www.gotech.co.za/welcome.htm
Gotech MFI Information and Features
- Can be used on vehicles with a single coil and distributor setup with trigger per event
- 1, 2, 3, 4, 5, 6 and eight cylinder compatible for fuel and ignition control
- One injector driver, one ignition output and one optional output (can be used for direct firing of ignition coil)
- 32 Load sites
- 3d Ignition and Fuel control
- Optional launch control
Basic Kit Contents
The basic kit includes
- Gotech MFI ecu
- Universal wiring harness
- Software package
- User manual
Dressed looms can be supplied on demand for vehicle specific applications.
Ignition Control Features
- Full Control over ignition timing at preset RPM intervals and 32 load sites
- Interpolation Between load sites for smooth timing transition
- Ignition control input provided by engine speed and manifold pressure (TPS also available)
- Soft touch RPM limiter is provided to prevent dangerously high RPM to be exceeded
- Ignition is fully programmable using serial link to Pc or laptop
- Windows based software
- Timing control up to 12000 rpm
Fuel Injection Features
- Batch Firing of injectors
- Full control over electronic injectors over 32 load sites and preset RPM levels
- Interpolation Between load sites for smooth transition
- Able to drive 4x 2ohm injectors or 8x 16 ohm injectors
- Fuel injector time mapped at 500rpm from startup to 12 000rpm on a 4 cylinder engine
- Injector time is fully programmable using the windows based Gotech software
Sensor inputs
- Manifold air pressure (Built in 1,5 bar manifold pressure sensor, optional 3,0 bar map sensor available)
- Intake air temperature
- Fluid Temperature
- Throttle Position
- Engine Speed
- Lambda (Closed Loop Control)
Additional features include
- Offline tuning
- Files can be uploaded and stored on your computers hard drive for future use
- Real time fuel adjustment using the fuel pot. Fuel adjustable by 10% richer and leaner over the - whole range while driving.
Software Features
- Windows based. Can be used with Windows '98 , ME and XP
- User friendly interface with easy to navigate screens
- Dash panel for engine monitoring whilst online.
- Files can be downloaded an retrieved on hard drive
- Files can be uploaded to the MFI and saved to the hard drive.
- Maps can be rapidly changed using the curve function or the all ranges up.
- Input screens include: Fuel, Ignition, F5 Configuration, Air temp correction, Water temp correction, Battery voltage correction and the micro staged fuel map.
- Online data logging with a sample rate of 30hz. Data is displayed on a user friendly field.
Optional Extra
ST Labs USB to serial adaptor. Works great on Windows XP
- 32 Load sites
Basic Kit Contents
- Gotech MFI ecu
- Software package
- User manual
Sensor inputs
- Fluid Temperature
- Throttle Position
- Engine Speed
- Offline tuning
Software Features
Optional Extra
