Cams & oil pressure
Old Sep 23, 2008 | 11:51 AM
haz87's Avatar
haz87
Default Cams & oil pressure
Would a badly ground cam cause low oil pressure? I've done a cam swap (new cam fitted with new lifters) and my oil pressure has plummeted. I was wondering if it was badly ground and the journals were smaller by a tiny tiny amount would this cause bad oil pressure? Its on a cvh btw
Old Sep 23, 2008 | 12:12 PM
RichieST's Avatar
RichieST
Is it low pressure all the time, or just at tickover/high revs?
Old Sep 23, 2008 | 12:33 PM
haz87's Avatar
haz87
Its higher at cold start and does pick up slightly when rev'd at warm. But it is nowhere near where it was with the old cam
Old cam -
Cold start 80~psi
Warm rev'd at 3000rpm 40~psi
New cam -
Cold start 35psi
Warm rev'd at 3000rpm 20psi
Old Sep 23, 2008 | 03:18 PM
haz87's Avatar
haz87
bttt
Old Sep 23, 2008 | 03:20 PM
pee vee's Avatar
pee vee
thats a bit odd... sure you didnt drop anything in the engine while you were changing it?
cos elle
Sep 25, 2015 09:52 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
dombanks
Sep 21, 2015 08:38 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
