twin 40s on my xr2, cant get fuel pump to work
Old Sep 23, 2008 | 11:11 AM
primedog's Avatar
primedog
Default twin 40s on my xr2, cant get fuel pump to work
can anyone help me out, iv jus put a fresh engine in my mk2 xr2 n put 40s on, problem im havin is my facet fuel pump is knakerd, so i had a cossie one floatin about n put that on. i checked it worked by hookin to battery n earth n it threw petrol over my engine bay so that was cool, i plumbed it in to the regulator n charged batry, wen put battry bak on i hooked pump to ignition n it aint workin, checked it on the batry agen n it aint workin, think i blew it up. do i need to hook up a relay of sum sort???? did anyone encounter this problem??? or hav same set up n all workin??? let me no pls sum1.......... cheers nathan
Old Sep 23, 2008 | 11:12 AM
Markb_s1's Avatar
Markb_s1
pretty sure you shouldn't use a cossie pump with carbs as it'll be a high pressure one. you need a low pressure pump like abother facet. red top would do it i imagine.
Old Sep 23, 2008 | 11:16 AM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
could be the pump is foobar.cos pumps rely on the petrol to lubricate them,so running them dry,even on a test,can stop them working.
but a cos pump is too high pressure for use on twin 40s,buy another facet.
Old Sep 23, 2008 | 11:18 AM
NEWTON's Avatar
NEWTON
you need a facet pump
primedog's Avatar
primedog
no money at minit so was usin wot i had, iv also got a pump from a mk4 cab 1.6 efi. was gonna try that wiv a relay... i no shud use a low pressure to run it but i jus want it to start up really. the fuel pressure reg takes care of fuel befor it gets to carbs so wudn do anythin bad i wudn say. is that a pic of ur escort??
Old Sep 23, 2008 | 11:19 AM
The Youth.'s Avatar
The Youth.
as said DO NOT USE a cossie fuel injection pump, you need a facet silver top for your application..
steve
Old Sep 23, 2008 | 11:23 AM
primedog's Avatar
primedog
red or silver top facet? difference being??? like i sed befor i jus wanted to fuel it to hear it run so was not gonna keep it like that.. jus want sum fuel in the carbs n start her up.... appreciatin the resonses thanks.
Old Sep 23, 2008 | 11:24 AM
primedog's Avatar
primedog
is that a pic of ur escort?? is it finished yet? im after a mk2 escort at minit.
Old Sep 23, 2008 | 11:32 AM
RichieST's Avatar
RichieST
You're asking for advice, completely disregarding any given, then wonder why your still having problems
You NEED a lower pressure pump, pumps that supply a FI system run at too high a pressure.
Old Sep 23, 2008 | 11:34 AM
Markb_s1's Avatar
Markb_s1
i think red top is higher flow but don't quote me on it. i've got one i was gonna use in the escort but that was on 45s.
yep, my escort but sadly the shell's being sold to someone.
never got the chance to finish it but unfortunately i need the money so it's got to go.
Old Sep 23, 2008 | 11:48 AM
The Youth.'s Avatar
The Youth.
as said the red top has a higher fuel flow rate than the silver top, for a standardish 2.0 engine a silvertop will be fine.
steve
Old Sep 23, 2008 | 02:00 PM
Hardeep_Singh's Avatar
Hardeep_Singh
i had a facet one on mine
Old Sep 23, 2008 | 02:03 PM
madmack99's Avatar
madmack99
I Love BooST
we run that set up and you need a facet pump
Old Sep 24, 2008 | 12:10 PM
primedog's Avatar
primedog
not disregardin the advice m8, was only syin i used wot i had around to get motor started so cud hear the 40s, I DID NOT SAY IM GOIN TO USE THE COSSIE PUMP TO RUN CAR. i appreciate advice and wen got sum cash wil b gettin another facet...
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
