Group A rally cars battery ?
Old Sep 23, 2008 | 09:07 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Default Group A rally cars battery ?
Was wondering which battery they used in the group A escorts for example. With lamp pod, fog lights, and the 150Amp alternator.
Old Sep 23, 2008 | 09:30 AM
ian sibbert's Avatar
ian sibbert
We use the Varley (DMS) 30 Matt....
With a 200amp TAG Alternator...
http://www.varleyredtop.com/products_30.htm
Old Sep 23, 2008 | 09:34 AM
wayne thomas's Avatar
wayne thomas
Same for me supplied by http://6r4.com
Old Sep 23, 2008 | 09:36 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Do you know how much Amp/h it flows Ian ? Thank you as usual for your answers.
Old Sep 23, 2008 | 09:41 AM
Mad Matt's Avatar
Mad Matt
Rally nut
Have seen 25 Amp/h but looks quite low to me. Normal road cars does have 65 A/h battery (saph cosw). I know rallycars don't need to have large capacity because they can charge the battery offstage, but still.
Old Sep 23, 2008 | 10:45 AM
ian sibbert
Matt,
We never have any major issues with the Varley 30 pal, they provide adequate reserve and cranking output for even a high compression YB...
If its for a road car you might be better with a conventional battery in a battery box..
We always fit a 200A anderson plug for parallel connection of either a piggy back battery or jump pack (just in case)....
The beauty of the dry cell is the absence of nasty fluids and fumes and the flexibility of location options....I have mine mounted in the passenger footwell, behind the footrest, this keeps mains cabling down to a minimum and prevents lots of voltage drop....
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
matman
Sep 9, 2015 05:45 PM
track.focus'd
Aug 12, 2015 05:53 PM
tankybaby66
Aug 9, 2015 07:13 AM
xr_craig
Aug 7, 2015 06:00 PM
