S1 problems.
Old Sep 22, 2008 | 10:06 PM
Dave100e's Avatar
Dave100e
Default S1 problems.
My series 1 keeps stuttering.
Sometimes when i give it some beans and hit the limiter once or twice in second the overboost kill switch comes on. Is there any way to stop this as im running roughly 1bar and ive been told its set to 1bar.
Also, under similar circumstances if the limiter comes on, i think its sticking. Youll drive along and the car will suddenly start to die and pop shit out the back etc. Its ok on overun, and idles a bit lumpy and low and struggles when you rev it, but if you revs the nutrs off it itll clear out. But then when you put the engine under load again it does it.
I took it out on sunday and gave it some proper abuse and then sat around for a bit. After i switch it back on it sat idling for about 20 minutes then just wouldnt drive away. So i left it for 5 minutes, tried again and it wasnt so bad. Then it cleared out and was fine.
Anyone got any ideas?
Old Sep 22, 2008 | 10:11 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sounds like it needs a good setup to me!
Old Sep 27, 2008 | 09:38 PM
rs shawn's Avatar
rs shawn
S1 Database Editor
Surely that's working correctly then? Overboost comes in at the top rev limit and the limit is set to what you are running
As for the other, sounds like it needs setting up before anything bad happens. Certainly wouldn't be giving the engine a battering without knowing it was fuelling correctly.
Old Sep 27, 2008 | 10:20 PM
Dave100e's Avatar
Dave100e
I want it to stop coming in though as its getting annoying. If i could reset it id prefer that but i want rid really.
Im getting an RR run soon and i will speak to the guy doing it about setting it up and what he can do.
Old Sep 27, 2008 | 10:39 PM
craigos's Avatar
craigos
that looks 1 tierd s1
Old Sep 27, 2008 | 10:40 PM
craigos's Avatar
craigos
prob needs a tune up
Old Sep 28, 2008 | 07:36 AM
rs shawn's Avatar
rs shawn
S1 Database Editor
I'm confused to what you actually think the limiter is. You can't remove or reset a rev limiter (you could maybe remove it with the right technology but think you'll damage the engine).
It's all down to the engine really and running full power on the limiter all the time will damage your engine.
Think of it as you on a bike. Eventually if you don't change gear you will tire as you are pedalling as fast as you can and cannot physically go any faster. You've reached your limit in that gear. Exactly how a rev limiter works - prevents an engine from over-revving at high revs. The limiter is there to stop the engine being damaged.
Have a read here on limiters
Some info from others (non-Ford) looking to remove the limiter - but pretty sure most will advise against it. Browse the topics here
Old Sep 29, 2008 | 06:34 PM
Dave100e's Avatar
Dave100e
I know what the limiters there for and i dont want to remove it. I know the standard limiter is mechanical and theres nothing i can do about it unless i get drastic.
I want to remove the overboost switch or at least raise the point which it comes in.
Ive been told they come in at 1 bar, and my actuator is set at just under 1 bar. If i hit the limter two or three times consecutavely i.e. wheelspinning, the overboost kill comes on and i have to wait a few seconds to carry on. I dont want to fit a bleed valve as i dont want to starve the engine. Is there anything i can do about it?
oilman
45
Dec 11, 2005 05:39 PM
Graceland
15
Nov 28, 2005 02:13 PM
cabcul49
Jun 16, 2005 07:03 PM
Richie.
May 23, 2005 10:26 PM
Brooke
Oct 26, 2004 08:44 PM
